Hey man, was gone for the weekend.
Keep in mind that not all banshees jet the same. While I'm running a 230, you might be at 190, or 210, or whatever. Your plug will tell you where it needs to be.
I'd concentrate on getting the main jet set right, then move on to the pilot later. One at a time. If you move both and it runs funny, you might have trouble figuring out what caused what.
Now, regarding the main. You might throw in a 210 and see what color your plugs are. If they're black an oily wet, then you need to go down one size and try again.
Once you get the main where you want it, then play with the pilot. If your at 48 and it doesn't hesitate, then your good, if it hesitates then goes, you might move up to a 50. I'd suggest putting your needle in the 4th clip down from the top/blunt end. Down (away from the blunt end) is richer and up (towards the blunt end) is leaner.
Just remember, take it slow and be patient, and your plugs will tell you everything. For more info on reading plugs, BenBB's jetting FAQ is a good place to look. Good luck.
Later,
Scott
