sredish
sredish last won the day on January 6 2019
sredish had the most liked content!
2 Followers
About sredish
  • Birthday 07/13/1977
Contact Methods
  • AIM
    scredish
  • Website URL
    http://community.webshots.com/user/sredish
    Chandler / Gilbert AZ
  • Interests
    you name it
    Last year (whatever that was) LE banshee.
Recent Profile Visitors
4,682 profile views
sredish's Achievements
HQ Commander In Chief
HQ Commander In Chief (5/5)
4
  1. ok. sorry for not being around much over the weekend. combination of a birthday weekend (someone else) and a sick kid can do wonders for free time..... anyways, here's where we're at: SOLD Gas Tank Front Bumper Grab Bar Rear Brake Assy Pegs / Heel Guards A-arms/Tie Rods Rear Hubs PT Pipes Stock Cylinders Stock wheels/tires PENDING Frame Frame Hardware Headlights Harness Bottom End (minus clutch) Plastic Still have everything else to sell. Stock Head Milled Head Passion Ported cylinders (might be a slight score mark and are on a pretty large bore) Front hubs Handlebars Stem Seat Shocks (front and rear, black) Radiator (and hoses) Swingarm and linkage (black) Stock carbs Stock intake and airbox Stock axle Gotta make a run to work on getting some stuff shipped. PM me and I'll get back as soon as I can.
  2. Black shocks, excellent condition. $175 shipped. Black front hubs, bearings are excellent. $75 shipped Black front a-arms in excellent shape. Joints are perfect, front brakes are good spindles are clean. It's all there and in new condition. If needed, I can pull the spindles. Black rear swingarm. Great shape. Has a little sand stuck to it from the chain grease, haven't cleaned it yet but it's perfect shape and bearings are great. Axle is good and straight. Haven't pulled it yet but will tomorrow.
  3. crazyj, i sent you a pm earlier. then i just got one from you but not in reply to the one i sent. the button on your message says "you cannot reply" so it won't let me for some reason. look for my pm to you and if you don't see it, pm me your phone number and we can text or something.
  4. ok, so all PMs have gone out, i've answered all the questions and am going out to garage for a bit to get some work done. i'll check back in a little bit.
  5. I intend to just been busy working on other things and haven't gotten everything off and itemized. I'll come up with something here in a bit.
  6. PM sent Tankdogg.... Also wanted to add an item that I forgot about. I have a pair of rear Hardkor hubs that are Honda pattern. So, if you have a few Hondas in the stable and get tired of being limited in usage for what tires / wheels work with which bikes... this fixes all that. Use all your honda stuff on your yamahas. this should fit the YFZ as well and possibly the raptor. All billet aluminum, they're black anodized and super trick. They're virtually new. I used them in the sandbox once. Pretty much like this:
  7. Infamous, I'm working on something with the bumper right at the moment. If it doesn't work out, I'll be in touch with you quickly! Everybody's PMs have been replied to. I'm tired and am going to bed so do not expect a reply until the morning please. I'm going to start ripping more stuff off. I'll get some pictures up as I can and will respond asap as well.
  8. got pm's cleared. so, looks like i have the following set aside (pending payment): frame headlights harness bolts / hardware bottom end minus clutch i still have the whole rest of the bike to sell. stock original bore (still have factory cross hatch) unported cylinders. stock intake, carbs, etc. milled head (for pump gas) wheels (black) w/ stock tires black stock swingarm stock axle stock radiator black bumper black grab bar gas tank black factory shocks hubs brake parts pegs another pic of the bike: here's pics of the stock top end: pic of the milled head:
  9. On phone can't delete pms rt now, I'll clear in a few after dinner. And I'll respond back via pms shortly. Sorry
  10. forgot to mention. also have a milled stock head for pump gas along with the orig stock head. both are off at the moment.
  11. ok so you guys know shipping plastics is a muthafucka..... i can get a quote. i'll have it for ya tomorrow.
  12. Alright. So, I have an 06 with not a lot of hours at all, maybe 10 or 15. Bike is stock except I pulled the stock jugs, pistons, carbs, intake and set it aside in a box and replaced them with passion ported cylinders, vforce reeds and a pair of 33mm carbs. Carbs have since been sold. There's a crank bearing that seems to be going out. I'm not 100%, need to take a better look but there might be a slight scar on the cylinder wall and there was for sure some heat on the piston. With this little amount of hours, i'm not sure what happened but the bike has mostly sat for awhile. I recently changed the oil and everything and went to get it started (for a sale) and there was crank noise. Tore top end down and saw some piston heat and scoring. I'm guessing something happened with lube to it. So, rather than screw with it, I've decided to do a complete part out. I'll get an inventory list going here in the next day or so. Frame, headlights, bolt hardware and harness may be spoken for. Pipes and aftermarket carbs are gone. Still have stock carbs and possibly a 38mm 2-1 carb w/ oversize bowl setup. Other than that, everything else is up for grabs. So, if there's something you need specifically, let me know and hopefully I can get straight to that part and get it to you. Here is a quick picture I have of the bike before I pulled the top end. These wheels are not part of it, they're honda. It has the stock black rear wheels and tires that match the front. I also have some HardKor hubs that fit Yamaha and are Honda pattern. Not sure yet if I'm selling but I'll think about it, they're expensive and hard to buy back.
  13. For Sale: Paul Turner Hi Revs Fatboy Silencer Quiets (w/ the turndown) I purchased these new for an 06 Banshee LE that I bought with nearly any hours. I put these on and some ported cylinders and went on one weekend trip. That's it. I bet they didn't accrue over 4 or 5 hours as I had my 450r there as well and rode it mostly. The bike has sat for a good bit while I moved and stuff. Now I've decided to go another direction and am selling these. They're great great pipes, one of the best imo. I'll let them go for $500 shipped.
  14. I have a whole 33mm PWK intake kit for sale. Includes: 33mm Keihin PWKs ($350 value) Dial-a-Jets installed ($140 value) Boss Billet Intake ($150 value) Dual K&N Filters / Outerwears ($125 value) Dual carb throttle cable ($40 value) Gaskets & clamps (who knows) Roughly an $800 value. I'll ship for $500. It's ready to go in a box and ready to run on your bike. (sorry for the horrible iphone picture)
