JKJK
    3
Everything posted by JKJK
  1. The inside of the bushing is aprox 10 mm.The only thing that goes through the bushing is the bolt that holds the a arms on.Are you talking about the end caps that sandwitch the arms inbetween the mounting points?
  2. outside of bushing is 21mm inside of sleeve is 20.90
  3. Need more info,Temp,elevation?Assuming sea level+70 deg. 300 mains stock pilot,middle clip pos.1 1/2 turns out with air screw.
  4. JKJK
    YFZ Spindles
    Somebody has to have some of this stuff laying around.I have cash and or many banshee parts for trade.
  5. JKJK
    YFZ Spindles
    YFZ Spindles,hubs,brakes,+rotors.Must be in excellent condition.
  6. Is the crossover hose in place between the carbs?If so i would start by switching the coil wires to the jugs+see if the problem follows+go from there.
  7. Nice stuff Jeremy! Good seller here people,no worries.glws
  8. I hate to here news like this.Where about in Ma?I'm from the Cape,I'll spread the word locally.
  9. Pal I'm Interested in your pro mod tranny.Please pm me your phone # for more details.John
  10. I would start with the 310's,going lower in #'s will make it leaner!Always safer to start rich+work to the sweet spot.Those specks should be real close to optimum.
  11. You must at least loose the snorkel.With temps.around 40 deg.1+1/4 turns out with air screws,25 piolet,middle clip,+310 mains.That should be real close,You'll probably have to go down one or two sizes on the mains+adjust the needle as needed.
  12. Welcome to the site.There are some very knowledgeable+helpful people here as well as the usual clueless clowns.Choose wisely who you absorb information from.For used banshee parts (NYUK)is the guy you want to deal with if possible.No bullshit+honest as the day is long. John
  13. If it is a stock front end set up,the only adjustments are the tie rod ends.
  14. Pittsfield Is hard core rocks+trail ridding,But it's ligit+you can make a weekend of it if you camp.I'm from the Cape,what kind of tech help you looking for?
  15. That place is in Cannon NH.Myself+our group had a great time there last spring.My bro just talked with the owners last month.They sold the place+it's closed now.
  16. I would guess you will find some sort of issues with your cooling system components,worn impeller,clogged radiator,ext.The Cub cylinders should run cooler than the stockers.
  17. A set of JJH needles should give you the results your looking for.Depending on how temperary they will be,you'll have to decide if it;s worth the cash output.
  18. I would agree with the jettinng recomondations.Also be cautious with any extended throttle in or beyond 4th gear.You will suck those those bowls dry very easily. Unfortunately i know this from experence.
  19. On LSR replacement bal joints the threded length is aprox 2 1/4 inch.
  20. Your pilot circuit is lean.Go up with the pilot and in with the air screws or both.You should have jjh needles,45-48 pilets,+155-162 mains for your setup.
  21. Dave Good to see your still kickin.I noticed one of your Imperial house of bearing enlightment center stickers on my toolbox the other day+ thought of the old days. John
  22. Where are you located? I'd be interested in some dyno time.
  23. I would recommend dropping the needle to lean out the mid circuit,change nothing else+ report back with findings.I'm sure we can help you out. By changing only one thing at a time+testing.Note the change in performance+let us know the results.
  24. If it's slightly rich it will struggle+not rev cleanly to peek .If slightly lean it will usually rev up quicker but be zingy+pop through the pipe.
  25. I'm going to assume your uninformed+leave it at that .R.I.P. Brooke
