Big Mike NY
    4
Everything posted by Big Mike NY
  1. Thank you very much. If your motor is stock and does not warrant the use of "high octane", it will slow you down.
  2. In colder conditions, do you have to lean down or fatten it up? Is it crucial to do so even if you are running a high enough octane?
  3. Shorter skirt, enables the use of a big stroker crank, I think.
  4. Blue Deuce, The highest Sunoco unleaded race gas is 104 octane. All Sunoco race gas above that is leaded. http://www.racegas.com/fuelspecs/default.asp Donuts, you will not benefit from the higher octane on a stock motor. Higher octane has a slower burn rate and if your motor doesn't warrant the use of high octane, it will slow you down.
  5. Not sure. Whatever Alba sent me with the cool heads are the domes I'm running. I run it on pump gas.
  6. First, if I switch to the high compression domes, what do I have to do besides run high octane, do I need to rejet? Second, what CC dome do you recommend? Octane is no object, its readily available where I live. Third, is it worth switching to high compression domes? Will I see a noticable power gain? Thanks In Advance!
  7. My 03 Alba Banshee is on the way! Should be here by Friday! So yes, technically I own one on paper, just don't have possesion of it yet!
