Kick Lever...
I found out my kick start is vibrating, and causing the most annoying ringing I've heard in my life. All the bolts and nuts are tight. Any tips?
(It's the lever ringing...the kick start as a whole is fine and 100% functional. I think it's just worn.)
if you undo the phlips head screw, there is a oring and a little spring and a small ball bering (looks like a bb). they make a kickstart rebuild kit for those. ther like 9 or 10 bucks. cascadeinnnovations shells them, i have had to do 3 of mine allready cause i got annoyed at the ratteling
http://67.199.65.66/cascade_innovations/ne...ore_dept_id=199
find a oring to fit it and the screw is ok that will work sometimes.
agree, all you need is a new o-ring also put a little grease in there
you can buy the parts from a dealer to rebuild them... i think its under 5.00 if I remember right. Yep its under $5
o-ring 93210-14369-00 $.99
spring 90501-12081-00 $1.49
Steel ball 93507-32031-00 $.52
screw if needed 90152-06010-00 $.78
Edited by Fouledout421
Here's what you do...
You go to the hardware store {Sears, Ace etc.} and buy...
1- .25" steel ball bearing
1- M6x40 allen head screw {I'll give instructions on how to find the right one later}
1- #8 spring
1- #2 spring and
1- #86 spring
A- Take the kicker off the bike and clamp it in the vice.
B- Remove the kicker lever. If the screw is stripped, drill a 3/16 hole into the OTHER end of the screw not into the head of the screw. You should be able to use a screw driver or a chisel and work the screw loose now.
C- Be careful to save the stock spring that is behind the ball. {if it's still there}
D- Use a Dremel tool to open up the hole in the post big enough to fit the .25" ball into it. DO NOT use force to fit the ball into the hole, you'll NEVER get it out.
E- smear some grease into the hole and then put in the original spring {or one of the springs listed above. You will need to cut it down if you use one of the hardware store springs}
F- smear more grease onto the post that the lever slips on to.
G- Take the cone shaped spring and cut it in half and put it on top of the post with the small end facing up. Make sure the spring isn't so wide that it is wider than the post. If it is, cut it down some more or bend in the part that sticks out.
H- Slide the kick lever onto the post and screw in the allen screw to hold it on.
******** Here's where you need to know how to get the right allen screw. ***********
When you go to the hardware store, take the kicker with you. You want to buy an allen screw that has a shank {the unthreaded part} that is long enough so that NO threads are in the groove area of the post. To find this out, thread in the screw into the kick lever all the way. Then look into the hole in the bottom of the lever and see if there are any threads visible in the hole. If not, then you have the right one.
I- After the kicker is completely assembled, make sure it rotates smoothly. Then cut off the rest of the allen bolt that's sticking out and re-install the kicker.
It should last a lifetime. Some guys will re-install an O ring. That's up to you.
Like I said, I'll do it for free but you have to pay the shipping both ways.
Man.. That sounds like alot of work.. when you can just spend 2-3 bucks and 15min of your time and its done.. and their isn't any searching for parts. Not saying your way wont work.. it just dont sound feasable to me. But... to each their own. :thumbsup:
Thats like HOLYMAN's mod the difference is you wont have to worry about tha kicker ever again.Repacement parts always have to be replaced.This mod is bullet proof. :thumbsup:
to each their own.. but thats way more time then I'm willing to spend on a kick starter when it only cost 3 bucks and 10 minutes if that to change them.. Bullet proof as it may be.. you still have to weigh the time and effort against cost and to some people its just not worth it.
I'm going to order the rebuild kit and see how it goes since this is the first time.
In the future, I would have no problem shipping it to you, and throwing you some money, and having it done.
