Parting out several Banshees - list of parts and prices
Here are the stock parts I have for any year Banshee
all parts are the price listed plus shipping, and yes, I combine shipping if you get them here
I have many aftermarket parts as well, but those usually go up on ebay
please email me at minkia38@gmail.com, my PM inbox here is always full
or you can bid on ebay: http://motors.search.ebay.com/_W0QQsassZminkia38
Running Engine $900.00
Rubber intake boots/Boost $30.00
Reeds and cages $25.00
Carbs and cable $100.00
Airbox (or air filter) $50.00
Kickstarter $50.00
Gas Tank $40.00
Pipes $35.00
Frame components
Frame $250.00 (title add $100)
Steering stem $45.00
A-arms / J-arms $300.00
Swingarm $50.00
Axle $100.00
Bearing carrier $50.00
Footpegs $15.00
Nerf Bars / Heel guards $40.00
Rear Hubs $50.00
Rear Sprocket & Hub $35.00
Rear Brake disc & Hub $35.00
Dogbone $20.00
Rear Grab Bar $20.00
Front Bumper Pushbar $15.00
Shifter $10.00
Skid Plate $20
Plastic
Front & rear Fenders $200.00
Radiator Plastic $35.00
Gas Tank Plastic $35.00
Seat w/ latch $75.00
Fender brackets $20.00
Electrical
CDI Box $60.00
Wiring harness / Loom $50.00
Coil $25.00
Headlights $60.00
on/off switch $10.00
Key w/ plastic housing $40.00
Taillight $20.00
Misc
Rear brake setup $100.00
Bolt set $40.00
Rear Shock $90.00
Front shocks $80.00
Front tires & rims $100.00 varies
Rear tires and rims $100.00 varies
Handlebars & grips $10.00
Clutch lever / perch $10.00
Thumb Throttle assembly $25.00
Radiator & Reservoir $50.00
Front brake lines $10.00
Front brake lever/rezzy $25.00
Motor Mounts $20.00
motor parts:
cylinders $300
crank $200
shift drum, rods, forks $60
gears/tranny $110
cases $200
clutch cover $40
stator cover $ 20
stator + plate $70
internal bolts $30
head $20
flywheel $70
