Bansh-eman Posted December 14, 2006 Report Share Posted December 14, 2006 anyone used the cascade heat shield wraps? any others you guys have used that you liked? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 14, 2006 Report Share Posted December 14, 2006 Your talking about the sock or sleeve type that you slide over the silencer tube to keep from melting your outerwear right? I have them and they work great. They barly get warm on the out side. You can grab them with your hand. I would say they are about the best heat protection you can get. They hold up very well too. josh Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted December 14, 2006 Author Report Share Posted December 14, 2006 Your talking about the sock or sleeve type that you slide over the silencer tube to keep from melting your outerwear right? I have them and they work great. They barly get warm on the out side. You can grab them with your hand. I would say they are about the best heat protection you can get. They hold up very well too. josh yea those are the ones... you get the half length or the full? also what you use to keep it from slideing? i was thinking just some hose clamps Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 14, 2006 Report Share Posted December 14, 2006 I just have the half lenght ones. I use them on my Toomey T5's. If your going to be putting them on your shear pipes I think that people usually use the full lenght ones since the stingers go up and over the filters. I need to find something to keep them from sliding. A hose clamp would probably be a little harsh on them. I was thinging about trying a couple of zip ties. I dont think they would get hot engough that they would melt them. You can get stainless steel zip ties made for header wrap. That would probably work the best. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted December 14, 2006 Report Share Posted December 14, 2006 Had them for a while, yes they do work well. Thing I didn't like is they hold sand, dirt, moisture etc... cause they are a loose fit around the mid-pipe tube. I opted to go with some header wrap and really like that route much better. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted December 14, 2006 Author Report Share Posted December 14, 2006 Had them for a while, yes they do work well. Thing I didn't like is they hold sand, dirt, moisture etc... cause they are a loose fit around the mid-pipe tube. I opted to go with some header wrap and really like that route much better. yea i was thinking just getting some header wrap too... we used to use that stuff on our pipes on the go-karts when we raced... you can get that shit at most auto parts stores cant you? Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted December 14, 2006 Report Share Posted December 14, 2006 Yes most O Riellys , Advanced auto, etc. and can order from Summit Racing also. I think most people use Zip ties on the heat shield wraps to keep most of the debris out. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted December 15, 2006 Report Share Posted December 15, 2006 Had them for a while, yes they do work well. Thing I didn't like is they hold sand, dirt, moisture etc... cause they are a loose fit around the mid-pipe tube. I opted to go with some header wrap and really like that route much better. word. i use header wrap too..works great.. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted December 15, 2006 Author Report Share Posted December 15, 2006 word. i use header wrap too..works great.. what you use to secur the header wrap? Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted December 15, 2006 Report Share Posted December 15, 2006 what you use to secur the header wrap? Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted December 15, 2006 Author Report Share Posted December 15, 2006 cool ... looks like im going to use the header wrap.. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted December 15, 2006 Report Share Posted December 15, 2006 If you get the kit from summit i think it comes with Stainless Steel Zip Ties. DEI is a good brand of header wrap. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted December 15, 2006 Author Report Share Posted December 15, 2006 (edited) If you get the kit from summit i think it comes with Stainless Steel Zip Ties. DEI is a good brand of header wrap. yea but i dont need 50 feet of it.. oh nm i see they got 15 foot ones too Edited December 15, 2006 by Bansh-eman Quote Link to comment Share on other sites More sharing options...
cam2 Posted December 16, 2006 Report Share Posted December 16, 2006 (edited) http://designengineering.com/products.asp?m=sp&pid=22 this is what i use. i bought them from advance auto parts for around $14 for two. there is a steel ring at the unstitched end that has to be removed. i undid the stitching and slid the ring out. then i folded the now unstitched end and slid it on the stinger first. they will stretch easily enough to slide on. i didn't use any thing to hold them in place but if i did i would use plastic tie wraps because they won't get no where near hot enough to harm the tie wraps or the outerwears. i've had no issues at all with them harming the outerwears. i will definitely use them again if need be. Edited December 16, 2006 by cam2 Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted December 18, 2006 Author Report Share Posted December 18, 2006 so after wasting 45 bucs on header wrap and metal ties ... i didnt even need to wrap my pipes... they clear fine already... oh well what can you do? Quote Link to comment Share on other sites More sharing options...
