people with stock banshees....
must have bonestock front suspension!
i need a favor, from someone
since i did my a-arm upgrade, i forgot too measure the width of stock suspension so i could compare it to the new width.
what i need is someone to take both front wheels off off their banshee and measure from brake caliper to brake caliper. just turn the bars ALL THE WAY to the right side (when sitting on it, preferably holding in position tight) and measure thru the frame caliper to caliper inside to inside.
then i need one more measurement. i think the easiest for this one would be to hook a tape measure into the end of the stock footpeg so its right into the end before it kicks up. and with the bars still in the right turn position measure out to the center of the front right hub bolt (center of the castlenut).
any one willing to do that?
shouldnt take but a few minutes to perform!
ideas on a better way too measure?
let me know
Edited by Mullet Man
Give you the measurements in a few minutes :beer:
Backing plate to backing plate is 33 1/4 length to hub bolt to peg is 27 inch's :evil:
thanks alot man! :cool:
how exactly did you measure it? i want to do it the exact same way!! i'm not sure what to consider the backing plate on the 4 wheeler. lol
and is the hub measurement to center of castle nut from the peg kickup?
i'll take pics of how i did mine.
OK,
this is how i did the measurements
http://i14.tinypic.com/2wqcpqt.jpg
notice how its hooked into the peg (outside edge of the very outside tooth) and i have the hub kicked all the way to the right. i get 25 1/4"
then this one, hub still kicked all the way to the right i went from inside of the left brake bleeder (caliper metal of the bleeder, not the actual bleeder) to same on the right side i got 35 1/4"
http://i14.tinypic.com/4ccrfqt.jpg
hey mullet did you ever get a chance to measure your stock arms? i would like to see if i can do a similar set up to my blaster. if it would work that would make a great "dumping ground" for banshee owners wanting to get rid of their stock arms.
sorry man, i forgot.
here they are tho!
http://i14.tinypic.com/2u7adc8.jpg
http://i13.tinypic.com/2yo4901.jpg
http://i13.tinypic.com/40kr4t3.jpg
http://i13.tinypic.com/4cto32u.jpg
the dust caps add approximately 1/8" to each bushing mount (see diff. in pics)
:beer:
thanks a ton. i'm going to go out and measure my blaster in a few minutes.
just measured my blaster mounts... the bottoms would be either a direct bolt on or pretty freakin close. but the uppers on the blaster are smaller by an inch.
thanks for measuring those for me.
Edited by nunyabinness
