Ban2000 Posted November 12, 2003 Report Share Posted November 12, 2003 Ok my Banshee broke a while back and i had to go out of town i came back and i found that most ifnot all my bolts needed to be replaced i have been looking arroung and i have found out that just for the bolts, bushings, washers and berrings to put my a-arms back on are like 300.00 and that is stock wow thats allot i am sure for that price i can get better aftermarket bolts and stuff if anyone has info... on were i can go to find cheaper stock bolts of aftermarker ones pleace let me know. Quote Link to comment Share on other sites More sharing options...
Blacksmith Posted November 12, 2003 Report Share Posted November 12, 2003 First of all, I am not sure what you have done to you bike that will require $300 worth of bolts and nuts to fix it. However, if you are looking for quality fasteners of any type or size try www.fastenal.com as they have pretty much anything you could ask for in common metric lengths and sizes. However, the front end on a banshee has a couple of bolts that are pretty specific to Yamaha. This is not to say that they can't be ordered from any other place, it is just that most of them will want you to buy 50 or 100. For those parts I would call James Crowder at "Your Banshee Connection". If you like send me an email and I will send you his number. Blacksmith@direcway.com Quote Link to comment Share on other sites More sharing options...
boonman Posted November 12, 2003 Report Share Posted November 12, 2003 I completely stripped my bike to the frame, and replaced EVERYTHING on it. that includes the bolts that you are talking about for the a-arms and all. Swingarm sleeve and bolt, all kinds of stuff. Cost me a little over $500 at the dealer. And that was for everything. i don't know where your going, but your getting taken for a ride.... Holyman can hook you up with a-arm bearings, and the dealer can get you the bolts. I just went and figured this all out. You are correct on the $300 tag. But, there are ways around a few things. Here is the break down for the stock components: Qty Part Number Description Price Total 1: 90381-15088-00 BUSH,SOLID $9.38 $37.52 lower, front 2: 90381-15088-00 BUSH,SOLID $9.38 $37.52 lower, rear 3: 90381-15088-00 BUSH,SOLID $9.38 $37.52 upper 4: 90387-101R3-00 COLLAR $6.04 $12.08 lower, front 5: 90387-101R3-00 COLLAR $6.04 $12.08 lower, rear 6: 90387-100Y6-00 COLLAR $15.82 $31.64 upper 7: 1UY-23517-00-00 COVER, THRUST 1 $5.12 $20.48 lower, front 8: 1UY-23517-00-00 COVER, THRUST 1 $5.12 $20.48 lower, rear 9: 1UY-23517-00-00 COVER, THRUST 1 $5.12 $20.48 upper 10: 90101-10655-00 N/A $0.00 $0.00 lower, rear, bolt, dealer stock 11: 90101-10655-00 N/A $0.00 $0.00 lower, front, dealer stock 12: 90105-10651-00 BOLT,WASHER BASED $6.80 $13.60 upper 13: 90201-10430-00 WASHER,PLATE $2.29 $4.58 lower, front 14: 90201-10430-00 WASHER,PLATE $2.29 $4.58 lower, rear 15: 90201-10430-00 WASHER,PLATE $2.29 $4.58 upper 16: 90185-10120-00 NUT,SELF-LOCKING $3.99 $7.98 lower, front 17: 90185-10120-00 NUT,SELF-LOCKING $3.99 $7.98 lower, rear 18: 90185-10120-00 NUT,SELF-LOCKING $3.99 $7.98 upper SubTotal $281.08 Type of shipping: Standard Shipping $22.50 Total $303.58 Here is another beakdown, everything consolidated: 90381-15088-00 BUSH,SOLID $9.38 $112.56 90387-101R3-00 COLLAR $6.04 $24.16 90387-100Y6-00 COLLAR $15.82 $31.64 1UY-23517-00-00 COVER, THRUST 1 $5.12 $61.44 90101-10655-00 N/A $0.00 $0.00 90105-10651-00 BOLT,WASHER BASED $6.80 $13.60 90201-10430-00 WASHER,PLATE $2.29 $13.74 90185-10120-00 NUT,SELF-LOCKING $3.99 $23.94 SubTotal $281.08 Type of shipping: Standard Shipping $22.50 Total $303.58 Now, you can omit the first item, #90381-15088-00, because these can be had from ebay, in a far superior product to stock, for like $40. Or, Holyman has the bearings. You may not need the collars either. I needed only the uppers on mine. Which are the 90387-100y6-00. The lowers were not a problem. SO, you are at a cheaper rate than initially expected. ANd the bolts are unacailable elsewhere. you have to run the stock spec bolts for the upper. You may be able to get away with the lower bolts, but I believe they are shoulder style bolts, and they aren't very expensive anyways. If your covers are shot, and you put them back on, they will just let debris right in, and toast everything again and again. So, the $60 is well worth it there. it is expensive, but needed..... Sloppy front ends are just no fun... Also, you can knock off the shipping charge on here, because you can order thenm from the local stealer. And they should be a little cheaper. this is the list price, and I know my dealer beats it every time, sometimes by alot..... It is up to you... Quote Link to comment Share on other sites More sharing options...
