98bonerSTOCKshee Posted September 4, 2003 Report Share Posted September 4, 2003 If anyone has added the single K&N filter to the air box they probably have same delima.... The box lid holds the fitler in place and it is a bitch to line up. I have noticed the the foam pad that seals the fitler to the box(going in carb. direction) isnt always properly sealed allowing dirt to bypass the filter.....So what I did was I removed the stock fitler mount replaced the foam and bolted that sucker in permanetly..the K&N filter still clamps on the mount allowing it to be removed, cleaned and replaced with out the hassle.. This also allows the removal of the box lid for more air. In wet muddy situations put the lid back on.. I messed up and had to shave the underside of the lid so it would fit around the bolts, this wouldn't be necasary if I had the bolts lowered a bit..Use gasket sealer around the bolts for that extra protection. I got pics if needed cant attach here...(i think I cant) Quote Link to comment Share on other sites More sharing options...
bignasty1 Posted September 7, 2003 Report Share Posted September 7, 2003 yeh i did the same exact thing to my friends bike while it was at my house i dont think i would ever buy a 90 dollar air filter holder when it took like 10 minutes at the very most to do and was so worth it then he was able to run no lid and it only cost him the cost of jets and not close to a hundred bux. good deal in my opinion. Quote Link to comment Share on other sites More sharing options...
1onice Posted September 12, 2003 Report Share Posted September 12, 2003 I'm not sure i follow you here. That doesnt look like a stock mount to me. Was that in there when you bought it, just not bolted in. Correct me if im wrong but the stock filter holder dealio is just a slot not a flange of any kind like you have there. Not trying to give you a hard time or anything, just a little confused! Quote Link to comment Share on other sites More sharing options...
josegarcia124 Posted September 15, 2003 Report Share Posted September 15, 2003 did the same thing to my shee and works great!!!! jose~~ Quote Link to comment Share on other sites More sharing options...
98bonerSTOCKshee Posted September 16, 2003 Author Report Share Posted September 16, 2003 I'm not sure i follow you here. That doesnt look like a stock mount to me. Was that in there when you bought it, just not bolted in. Correct me if im wrong but the stock filter holder dealio is just a slot not a flange of any kind like you have there. Not trying to give you a hard time or anything, just a little confused! yes the stock filter has a cone shaped plastic thingy, with you buy the K&N single filter it tells you to cut the coned end off leaving just the flat part that slides into the groove. It can be difficult at times aligning it into the slot, I noticed one day that it wasn't seeling properly at the carb. side. So I bolted it in permanetly.. The K&N can still be removed via the hose clamp... Still confusing? No offense takin.. Quote Link to comment Share on other sites More sharing options...
1onice Posted September 17, 2003 Report Share Posted September 17, 2003 ok now I gotcha i never even looked at the stock filter that close i guess. I bought the aluminum adapter with the clamp on k&n and tossed the original filter like a week after buying my banshee. Thanks for clearing that up for me. Quote Link to comment Share on other sites More sharing options...
i2mbored Posted September 19, 2003 Report Share Posted September 19, 2003 Is that the stock filter cage with the fins cutoff?? Quote Link to comment Share on other sites More sharing options...
98bonerSTOCKshee Posted September 25, 2003 Author Report Share Posted September 25, 2003 yes it's got the fins cut off. Quote Link to comment Share on other sites More sharing options...
barbwire Posted September 30, 2003 Report Share Posted September 30, 2003 when i did mine i left a litle mor than half the fins(lenth) seems to help hold the shape of the k&n prob dont need the rein forcement.also a couple small screws will help hold it on. Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted October 21, 2003 Report Share Posted October 21, 2003 I did the same thing Only I used Zipties instead of bolts, and Clear RTV silicone to ensure the plate was sealed against the box, I posted pics ont he old forum heh. Has been working great now for 4 years Quote Link to comment Share on other sites More sharing options...
