Misssppelllleddd Posted July 14, 2008 Report Posted July 14, 2008 I"m setting the thread up to tell everyone not to waste their money on the CRJ temp gauge. At least not until they fix the problem. Every time I would start up my 'shee the display would shut off after 140 degrees Fahrenheit and wouldn't turn back on for about another 24 hours. I held it in my hand thinking it was a vibration issue and still the same thing happened. This is the third gauge they sent me. What other companies out there make a good one? I heard Trailtech makes a good one. Quote
BansheeKid15 Posted July 14, 2008 Report Posted July 14, 2008 I"m setting the thread up to tell everyone not to waste their money on the CRJ temp gauge. At least not until they fix the problem. Every time I would start up my 'shee the display would shut off after 140 degrees Fahrenheit and wouldn't turn back on for about another 24 hours. I held it in my hand thinking it was a vibration issue and still the same thing happened. This is the third gauge they sent me. What other companies out there make a good one? I heard Trailtech makes a good one. I bought one a while back, and used it with the same results. I put a new battery in and sandwiched it as hard as i could to the back of the temp gauge... been fine since Quote
Misssppelllleddd Posted July 14, 2008 Author Report Posted July 14, 2008 What do you mean by "sandwiched it as hard as you could"? Quote
jbooker82 Posted July 15, 2008 Report Posted July 15, 2008 I have a trail tech vapor. It has engine temp, air temp, Temp waring light (orange) Overheat light (Red) The two lights are programable. RPM. RPM Shift light, (orange flashing light) Over Rev light (Red Flashing) lights are programable Speedo, Average Speed, Max Speed. Total Acumulated Ride time (hr meter) Ride time, Odometer, Trip odometer time It runs right off the stator with battery backup. I havent gotten to try it out yet because my banshee is down with out a stator. It should work sweet though. I did also buy the billit aluminum bar clamp protector. This is my last resort. I have tried all types of temp gauges. The Mechanical ones all fail because the vibration tears them up. I had an electric one. The voltage regulator came un pluged and smoked the gaugs. I was going to try an autometer mechanical liquid filled gauge but it was going to be to big and gody looking. I have a trail tech endurance on my raptor and it is still going strong 4 years later. The trail tech Lynix has an engine temp but no RPM. The Vapor cost a little more but it is worth it for the features you get. josh Quote
spurdy Posted July 16, 2008 Report Posted July 16, 2008 I"m setting the thread up to tell everyone not to waste their money on the CRJ temp gauge. At least not until they fix the problem. Every time I would start up my 'shee the display would shut off after 140 degrees Fahrenheit and wouldn't turn back on for about another 24 hours. I held it in my hand thinking it was a vibration issue and still the same thing happened. This is the third gauge they sent me. What other companies out there make a good one? I heard Trailtech makes a good one. I think this is the same one I bought. 1" x 2" dispay in an aluminum frame, handlebar mount? In line thromocouple for monitoring? I know mine quit working due to vibration. I have redone the battery connections and still can't get it to "stay" working while riding the bike. I can always get it to work again, but it soon loses the connection with the battery and stops. Not happy with the item at all. SP Quote
peterlocal22 Posted July 16, 2008 Report Posted July 16, 2008 i have an esr and love it. very basic but awsome Quote
BansheeKid15 Posted July 16, 2008 Report Posted July 16, 2008 What do you mean by "sandwiched it as hard as you could"? I took the backing off the battery, and then i shoved as much paper towel behind the battery to keep it foward into the prongs, and then some on top of it to hold the battery still. They are good gauges, but i wish they could have been made so we could splice the power of the bike into the gauge itself. Something i want to look into, see if its possible. Quote
peterlocal22 Posted July 16, 2008 Report Posted July 16, 2008 my bro has one and it seems owork great. Quote
Keyser Soze Posted July 16, 2008 Report Posted July 16, 2008 The thin plastic grove the battery cover slides under to secure the battery get streched out easy. Mine quit working after one day. I broke the plastic grooves out and hot melt glued the battery cover on. Been working for 20+ hours of hard woods riding since. Shouldnt be to bad stripping out the glue once a yeat to change the battery Quote
BillyRay Posted November 2, 2008 Report Posted November 2, 2008 Have the ESR like peterlocal22, great product and very simple. Quote
dragbanshee Posted November 2, 2008 Report Posted November 2, 2008 Have the ESR like peterlocal22, great product and very simple. Funny this thread just came up, I'v been looking into old threads trying to figure out which way to go with a temp guage. Quote
flyhighprerunner Posted November 2, 2008 Report Posted November 2, 2008 I think the trail tech vapor would be the way to go if you got the money otherwise the esr is the next best thing... Quote
2001Stroker Posted November 2, 2008 Report Posted November 2, 2008 i wish they could have been made so we could splice the power of the bike into the gauge itself. Something i want to look into, see if its possible. I wouldn't try it right to a power source, if you did. Since it runs off a watch battery, it should be about 1.5 volts. If you did it, you would need a voltage regulator, bringing it down to that voltage. You would probably also need to convert the bike to DC, and add a battery. I would be willing to bet that if you left it like it is, the LCD would blink when you're idiling, if it would work at all since it's AC power. Just a couple of thoughts. Quote
2strokespirit Posted November 8, 2008 Report Posted November 8, 2008 (edited) I sell trail tech vapors.... I had NOTHING but problems with them, I'm telling you I have my 3rd on the bike, I replaced like 100s of speedo "cables" for customers and a few computers, you have to run "R" plugs!! The next step to my vapor is ripping it of my bike!!!! It does have awesome functions, tach is not very accurate but its cool.. I mainly run it for the temp gauge part!! Edited November 8, 2008 by 2strokespirit Quote
jerseyrider Posted November 8, 2008 Report Posted November 8, 2008 dam i just bought a crj temp gauge i hope i dont ahve any problems with it .or i might just try to return it i still have it new in the box. what should i do ????thanks Quote
