wiseco pro lite to namura
#1
Posted 20 May 2008 - 01:11 PM
#2
Posted 20 May 2008 - 01:32 PM
#3
Posted 20 May 2008 - 02:00 PM
Did you check your squish with either set?
no i didn't, whats the easiest way? wouldn't think they would make pistons that different from one another?
#4
Posted 20 May 2008 - 02:04 PM
#5
Posted 20 May 2008 - 02:06 PM
#6
Posted 20 May 2008 - 02:56 PM
Eric
#7
Posted 20 May 2008 - 03:05 PM
unless whoever you took it too honed the shit out of the cylinders(seen this done) then your compression should be close, also you should have done a review on the Namura pistons which are cast..the skirts supposedly bust off really easy on them...
I honed it myself, and i didn't hone it alot, just enough to get the glaze off, the namura's seemed to fit tighter than the wiseco's did, i dunno, whats the squish supposed to be? i'll have to check it i guess,, thanks again guys
#8
Posted 20 May 2008 - 03:29 PM
#9
Posted 20 May 2008 - 03:49 PM
Did you check hot or cold? Cast pistons and forged heat up and expand differently.
Did you bother to check ring end gap?
#10
Posted 06 January 2010 - 12:58 PM
#11
Posted 06 January 2010 - 04:38 PM
#12
Posted 06 January 2010 - 11:23 PM
Um...what caused the skirt to break in the first place, that's the first question that needs to be asked.
Two things (Dave noted both):
1.) The piston skirt broke for a reason. Most likely, the bore is out of round or not square to the crank (providing nothing else is wrong with the engine.
2.) You can't put a cast piston in a hole machined for a forged piston and vise versa (The machining spec. / tolerances are different).
#13
Posted 08 January 2010 - 07:32 PM
I would certainly want to look closely at the squish clearance. Probably a good idea to pull the topend and get a more thorough QA inspection. As mentioned above, skirts don't just break for no reason.
Also keep in mind that that gauge is NOT a bible but merely a tool. Tools can fail.
Mull Engineering
