clutch adjustment
  • Please log in to reply
7 replies to this topic
#1 drksuroo
drksuroo
  • Members
  • Pip
  • 8 posts
Posted 15 March 2008 - 10:42 PM
I recently got my banshee and I have a question about the clutch. Whenever the bike is in gear and the engine is revved with the clutch lever pulled completely the bike still moves. I don't have any more adjustment up top near the lever. Does the clutch need to be adjusted inside? What's the best way to do this? Thanks!
#2 bansheejoel
bansheejoel
    HQ Captain
  • Members
  • PipPipPip
  • 1,500 posts
  • Gender:Male
  • Interests:BANSHEE'S
Posted 15 March 2008 - 10:52 PM
possiably to thick of gear lube, or worn clutch pressure plate
#3 hylander88
hylander88
  • Members
  • Pip
  • 96 posts
  • Gender:Male
Posted 16 March 2008 - 06:14 AM
yes you can adj it in a the basket.only thing is have to drain all fluid to get to it..get your self a clymer repair book if doing it your self...
#4 dekker
dekker
    HQ Soldier
  • Members
  • PipPip
  • 316 posts
  • Gender:Male
Posted 16 March 2008 - 08:15 AM
Take the clutch cover off and there is a screw and a nut that run directly through the middle of the outer pressure plate all the way in and makes contact with your ball and rod loosten the lock nut and turn the screw in when you get it to where you want it tighten the lock nut .... MAKE SURE IT IS TIGHT and then put her back together..... all done really easy
#5 drksuroo
drksuroo
  • Members
  • Pip
  • 8 posts
Posted 16 March 2008 - 09:46 PM
I understand that you have to remove the whole cover to get to the clutch as in the shop manual. Is there such a thing as a case that you can remove just the small clutch cover and get to the clutch? I took off the small cover and it was solid underneath. What's the point of that? Can it be modified? (I have seen the cascade ones with the removable side cover.)
Edited by drksuroo, 16 March 2008 - 09:52 PM.
#6 Screaming Yellow Zonker
    HQ Soldier
  • Members
  • PipPip
  • 585 posts
  • Gender:Male
Posted 16 March 2008 - 11:22 PM
there are companys out there that make a removable cover just for the clutch. I have one that is a stock modified.
Posted Image
#7 drksuroo
drksuroo
  • Members
  • Pip
  • 8 posts
Posted 19 March 2008 - 06:48 PM
Ok so I have successfully learned how to take off the cover because I've done it four times now. I adjusted the clutch so the arrows line up. When I shifted into gear the bike lurched forward (with the clutch in) and died. Next I adjusted so the arrow was on the left side like a friend of mine and others have suggested. Still lurches and dies when shifted into gear with clutch pulled. What the heck is going on?
#8 gitter done
gitter done
  • Members
  • Pip
  • 1 posts
  • Gender:Male
Posted 14 April 2012 - 09:33 PM
i was reading some of the questions about the clutch and you answered it i diddnt kno it was that easy to adjust. just wanted to say thanks..
