banshee spitting coolant from overflow
  • Please log in to reply
11 replies to this topic
#1 banshee boy 98
banshee boy 98
    HQ Soldier
  • Members
  • PipPip
  • 549 posts
  • Gender:Male
Posted 11 October 2004 - 11:43 AM
this is a good one. the motor will spit coolant out of the overflow once the engine is warm. but the coolant that is coming out of it is not that hot. you can touch it and yes it is hot but not that hot. about like dish water. the motor runs great, jetting is right. if you shut it off it will blow coolant out of the overflow. we tryed a differnt radiator cap. same problem??? any ideas?? blown head gasket?
#2 fixitrod
fixitrod
    HQ General
  • Members
  • PipPipPipPip
  • 4,895 posts
Posted 11 October 2004 - 11:47 AM
Did it just start doing this. Could be a head gasket or a pinched line. Mine use to loose coolant during rides and I did this...... http://kuoi.asui.uid...~john/tips.html
#3 Capone
Capone
    HQ Soldier
  • Members
  • PipPip
  • 830 posts
  • Interests:Money, Females, Beer, Banshees
Posted 11 October 2004 - 12:59 PM
-Thanks for the tip, glad I read this thread, doing it now :D
#4 banshee boy 98
banshee boy 98
    HQ Soldier
  • Members
  • PipPip
  • 549 posts
  • Gender:Male
Posted 11 October 2004 - 04:35 PM
it is a fresh motor. has about 10 hour on it. has been doing it since rebuild. it is 20 over. milled .030 head. mild port job. 2-1 pipe. k&n filter in the box. 280 main jets. it is not running lean and it is not getting hot. but it will blow coolant out if you are riding it and let off and run a low rpm, or just idle, or shut it off. only does this after it gets to operating temp. ???????????????????
#5 ranshee
ranshee
    HQ Soldier
  • Members
  • PipPip
  • 610 posts
Posted 11 October 2004 - 05:12 PM
Mine does the same thing after a good ride, but it does not seem to be running bad at all. Still has full power and pulls hard as hell and is jetted right. It seems to fall on the upper right a-arm.
#6 Ruko
Ruko
    HQ Soldier
  • Members
  • PipPip
  • 731 posts
  • Gender:Male
  • Interests:Kick'n' 4 stroke ass
Posted 11 October 2004 - 05:57 PM
Mine did the same thing... it was the head gasket leaking just a bit.
It ran fine and didn't get hot but it would pressure up and spit out all the coolant.
Try changing your head gasket.
#7 banshee boy 98
banshee boy 98
    HQ Soldier
  • Members
  • PipPip
  • 549 posts
  • Gender:Male
Posted 12 October 2004 - 04:57 AM
i will try the head gasket.
#8 fixitrod
fixitrod
    HQ General
  • Members
  • PipPipPipPip
  • 4,895 posts
Posted 12 October 2004 - 08:04 AM
Make sure you buy a stock head gasket from yamaha. Most of the aftermarket gaskets suck. Also, make sure your cylinders seem to be flush with each other on top while you have the head off. If you can get a good straight edge, lay it on there to check the cylinders and the head. I've been told the head gasket can fill in defects up to .006".
#9 banshee boy 98
banshee boy 98
    HQ Soldier
  • Members
  • PipPip
  • 549 posts
  • Gender:Male
Posted 12 October 2004 - 11:11 AM
should i spray the gasket with cooper coat? it should help seal it right?
#10 fixitrod
fixitrod
    HQ General
  • Members
  • PipPipPipPip
  • 4,895 posts
Posted 12 October 2004 - 11:24 AM
If you feel like you want to use anything as a sealant make sure it's a spray on. You shouldn't have to use anything with a stock yamaha head gasket.
Edited by fixitrod, 12 October 2004 - 11:25 AM.
#11 jeepman137
jeepman137
    HQ Soldier
  • Members
  • PipPip
  • 254 posts
  • Gender:Male
Posted 12 October 2004 - 11:33 AM
i was going to post about this too, im in school so i have to type this fast, lol :lol:
but the other day, i think saturday, i started the engine after draining some fuel, and was trying to get the last bit out of the carbs, so i was revving the engine, and i looked, and coolant was coming out of the overflow every time i reved the engine, not at the peak of the rev, at the bottom, like just before it started to idle again. it didnt pour out, but it didnt just drip out either...
also, after i drained the fuel and started the engine to get the remaining fuel out, i looked at the exhaust, and i noticed only one was smoking bad because of warm up, and that was the right side cyl., so i put my hand over the left, and revved the engine, and it wasnt even running... :unsure: so i dont know if this is because only the right side cyl. got the remain gas and the left was starved or what, but i got worried. i didnt have any mixed gas at the time, so i couldnt mix the right ratio and tryand start it then, so i still havent tried it, just wondering if i f*cked something up, or if it was just cuz the left cyl. was starved for fuel at the time...
any help would be appreciated...
oh yea, and sorry for kinda stealing your topic.
#12 Cotton eyed Joe
Cotton eyed Joe
    HQ Commander In Chief
  • Members
  • PipPipPipPipPip
  • 7,911 posts
  • Gender:Male
Posted 12 October 2004 - 09:04 PM
Damn Rod...you read my mind.
I just had 10 bottle brackets fabbed up to mount the overflow bottle in the front of the bike.
Works a hell of a lot better than hose clamps.
