streetshee Posted July 21, 2004 Report Share Posted July 21, 2004 when your all rebuildin truein and weldin ye cranks,do u ballance em too????? Quote Link to comment Share on other sites More sharing options...
streetshee Posted July 22, 2004 Author Report Share Posted July 22, 2004 hello? if not,why not???? Quote Link to comment Share on other sites More sharing options...
kenr74 Posted July 22, 2004 Report Share Posted July 22, 2004 Trueing the crank is the same thing as balancing it. Quote Link to comment Share on other sites More sharing options...
streetshee Posted July 22, 2004 Author Report Share Posted July 22, 2004 truing is the alighnment of the crank as i understand it? Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted July 22, 2004 Report Share Posted July 22, 2004 the crank balances itself....not like a single pistoned engine, it doesent need a counter balance Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted July 23, 2004 Report Share Posted July 23, 2004 The con rod journals are at 180 degree of each other. If you true them they are within .002 or less. Equal mass on both sides = balanced Quote Link to comment Share on other sites More sharing options...
streetshee Posted July 23, 2004 Author Report Share Posted July 23, 2004 because you true it to .002 doesnt mean that both sides of the crank are exactly the same weight,what is when one side is 1 gram heavier? Quote Link to comment Share on other sites More sharing options...
Bairdy13 Posted September 6, 2007 Report Share Posted September 6, 2007 because you true it to .002 doesnt mean that both sides of the crank are exactly the same weight,what is when one side is 1 gram heavier? Sorry to bring up an old topic but does anyone have anymore info on this topic? this was all i could find and i want to get mine welded real soon. Cheers Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted September 6, 2007 Report Share Posted September 6, 2007 (edited) when you wled the crank the amount of metal put on the webbing is not enough to worry about throwing your crank off. when you need to re-true it is when you rebuild it. just welding it you will be fine edit: that is assuming its not off right now. Edited September 6, 2007 by Bansh-eman Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted September 6, 2007 Report Share Posted September 6, 2007 my experience with cranks is this. true and weld is to make tdc and bdc exactly 180 degrees apart on a twin. Then weld the web so it does not come apart. Balance is to put the crank in a device and remove any uneven occilations from it as a rotating assembly. I had my old Banshee hot rod long rod crank done by these guys. They lightened, trued, welded, and balanced it for me. Falicon Cranks Link Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 6, 2007 Report Share Posted September 6, 2007 my experience with cranks is this. true and weld is to make tdc and bdc exactly 180 degrees apart on a twin. Then weld the web so it does not come apart. Balance is to put the crank in a device and remove any uneven occilations from it as a rotating assembly. I had my old Banshee hot rod long rod crank done by these guys. They lightened, trued, welded, and balanced it for me. Falicon Cranks Link There is absolutely no reason to balance a Banshee crank! (noy to say I have not done it for fun) However trueing is absolutely necessary. Falicon is a good company for such things, but others can certainly do the same work. On a personal rant, Falicon has terrible leas times and have several employees on the customer side of things that fill you up full of BS. They do make some neato cranks for the privateer super bike racing and drag racing folks. :wink: Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted September 6, 2007 Report Share Posted September 6, 2007 I did it all through my engine guy who is a friend of mine that I ride with and hang out with. He sent it to falicon and handled talking to them. I definitely felt like I got my money's worth when it was done. The crank was considerably lighter than before it went in, the bike revved very fast, and the engine ran very smooth. Quote Link to comment Share on other sites More sharing options...
blowit Posted September 6, 2007 Report Share Posted September 6, 2007 I think the terms "balance" and "true" are getting confused. They are NOT one in the same. Truing refers to axial and radial alignment of the crank. Balancing refers to adding or subtracting weight to obtain a "balanced" rotating mass. Balancing is not common on the Banshee but standard practice in many other engine applications. Theoretically, yes, the weld itself can and will cause balance problems regardless if fillers are used or not. After the fact though, I see no way to check or repair the balance of the crank when welded. In regards to the banshee, just properly truing the crank generally puts the balance close enough that it does not matter. We have seen countless new cranks that are welded up but trued VERY poorly. We have returned plenty because .006-.009" is just toooo much runout and your handlebars will agree. Brandon Quote Link to comment Share on other sites More sharing options...
David Keith Posted September 7, 2007 Report Share Posted September 7, 2007 I think the terms "balance" and "true" are getting confused. They are NOT one in the same. Truing refers to axial and radial alignment of the crank. Balancing refers to adding or subtracting weight to obtain a "balanced" rotating mass. Balancing is not common on the Banshee but standard practice in many other engine applications. Theoretically, yes, the weld itself can and will cause balance problems regardless if fillers are used or not. After the fact though, I see no way to check or repair the balance of the crank when welded. In regards to the banshee, just properly truing the crank generally puts the balance close enough that it does not matter. We have seen countless new cranks that are welded up but trued VERY poorly. We have returned plenty because .006-.009" is just toooo much runout and your handlebars will agree. Brandon Thanks for clarifying things Brandon. What you say is right. Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 7, 2007 Report Share Posted September 7, 2007 I think the terms "balance" and "true" are getting confused. They are NOT one in the same. Truing refers to axial and radial alignment of the crank. Balancing refers to adding or subtracting weight to obtain a "balanced" rotating mass. Balancing is not common on the Banshee but standard practice in many other engine applications. Theoretically, yes, the weld itself can and will cause balance problems regardless if fillers are used or not. After the fact though, I see no way to check or repair the balance of the crank when welded. In regards to the banshee, just properly truing the crank generally puts the balance close enough that it does not matter. We have seen countless new cranks that are welded up but trued VERY poorly. We have returned plenty because .006-.009" is just toooo much runout and your handlebars will agree. Brandon ....................beyond that on a 180 degree opposed firing twin, such as the Banshee engine, there is not any reason to balance the crankshaft. Each portion of the crankshaft related to the pins and arms can be really out of balance with respect to each other and the engine will still be fine, but the crank has to be true. If the crank isn't true and parallel it won't matter how well balance it might be. :geek: Quote Link to comment Share on other sites More sharing options...
