First realize the you will no longer be known as "TOOMEY MAN" once you make the swap.
Is it worth it?..........
  • Like 3
im not to lazy I just wanted some onions one which one to get.  for this setup bored .50 over. running pwk 35mm carbs. k&n filter .92 oct gas. br8es ngk plug. some other stuff (((soon to get cool head))))). does that help..
ok ok ok I would be riding trails to woods racing.
I would pick FMF FATTY'S for your riding.......but I don't want you taking the FMF MAN name.
I think ROCKETMAN is available..........
reply of the week!
Back to the OP question, I wouldn't buy either of those pipes. You want torque and bottom end, SLP all the way. There HP and TQ numbers are hard to ignore.
Well if you weren't lazy.. you would clearly know what pipe to run within 1 post research!!!!!!
SHEARER IS A DAMN DRAG PIPE!    people run them on 10mil cubs! ffs.....    if you would of asked FMF vs Toomey VS PC VS DMC VS PT or any of the mentioned ones I listed it would of made 10000000000000000 more sense and a fair question...
but shearer or DMC??? wtf....  one pipe is meant for drags and bigger built motors the other is a actual woods / trail pipe for smaller stock cyl builds....
If I finch this next motor... may just as well -.-
Did a penguin piss in your cheerios this morning or what?
  • Like 2
