I have one drag banshee, 4 mill Cub / twister on methanol (VP M5).
I want to play with nitrous setup, Want I need to know ?
Dirt drag, 350 feet long
Dry kit or wet kit its necessary with methanol ?
Your opinion about Boss Nos product ?
There was a cobbled together set up that I got the displeasure of sorting out. In the end it ran really well with a Dyna pulling the timing out but it had to be flashed like 6 times to make sure it ran the tune you last uploaded. It had a 12 volt Milwaukee battery that seemed to do well so it didn't have a bunch of weight. Fuel was managed with a NX pump and all the rest o the components were sourced through NX as well. Originally it was a boon dockers dry nitrous kit that some one tried make a wet kit. (Pure poop)
Edited by trickedcarbine
What kind of fuel do you use ?
And what kind of fuel do you use for the NX pump ? An auxilary tank whith C16 or main tank methanol?
C16 in the main tank. The guy had a really cool tank from Clark. It had two petcock mounts. The one on the left was a dual pinguel, the one on the right fed the pump for the nitrous set up.
How are you switching it? There are a lot of handy micro switches that work in the stock thumb throttle housing.
I use a nitrous express wet kit, nx fuel pump, close to a 4 jet spread, all race gas set up, snapper lawnmower battery and charger, dyna ignition,, stock head and gasket, arp studs , 165lbs static comp . I have no real time on set up or track time too busy working on other peoples junk
Somebody try Straitline Performance nitrous kit ?
Do you have some picture of your instalation ?
Are do you set the timming with nitours ?
What size jet ?
What plug do you run ? how is the gap ?
For the moment, I think swinching it with only push butom on the handle bar
What size jet ?
Everyone has to start somewhere, I get it. However, I think you need to spend some time reading, studying, and reading some more. There are some very in depth write ups on the net that can and will steer you in the right direction. At this point you are asking blanket questions that show you have done little research and are just asking people to spoon feed you.
  • Like 1
I never got the whole fixation with nitrous and Banshees.
I have a dual system on my race car. (Done prior to progressive systems)
It's a 100 shot in second gear, a 200 shot in third gear and both in forth for 300.
But a banshee is a different animal. At the push of a button your entire set-up becomes wrong.
Wrong gearing, wrong tire choice, wrong timing, wrong swingarm length.
If you have the bike set-up perfect for the use of nitrous......then it's all wrong without it.
For the cost of a nitrous kit, you could buy a much bigger and better motor and make big power all the time without a bottle and have a combo that works all the time.
Besides, as with every form of racing.......if you beat a guy and use nitrous to do it......there is no glory because he will dismiss the loss because you ran a bottle.
While there's a few experienced fellas poppin in, any one know where to find the non carbon fiber replacement reeds for VForce 2's? I thought TDR had some but haven't heard back on them.
Dismiss it he may, its a win. In your case why dont you build a bigger engine?
What?..... in my car?
