paultrombley98 Posted April 6, 2014 Report Posted April 6, 2014 I was adjusting the idle screw on my banshee today and I forgot to tighten the nut back on the idle screw and I took it out for like probably about two minutes around my back yard and I went to go adjust the screw again and it was gone. What will happen of I run it without the idle screw this my seem like a stupid question but im just curious Sent from my One X using Tapatalk Quote
tdod101 Posted April 6, 2014 Report Posted April 6, 2014 Worst you can do is suck up some dirt or w/e plug the hole with an eraser or tape till you get a new one, just make sure you take the other idle screw out too so at least they're in sync, than adjust the idle with the cable adjustment. Quote
paultrombley98 Posted April 6, 2014 Author Report Posted April 6, 2014 The cable on top of both of the carbs? Sent from my One X using Tapatalk Quote
tdod101 Posted April 6, 2014 Report Posted April 6, 2014 I'm assuming you don't have TORS on your carbs so you would adjust it by the throttle Quote
sheerider11 Posted April 6, 2014 Report Posted April 6, 2014 Air leak.....Pfffff an air leak? With a hole drilled in the side of the carb? Nonsense. Quote
Zillaguy Posted April 6, 2014 Report Posted April 6, 2014 The extra air might give it more power on that cylinder! LOL Quote
87sheestillkickin Posted April 6, 2014 Report Posted April 6, 2014 Id pull those out that and drill a hole in your intakes too. Quote
03DMshee Posted April 6, 2014 Report Posted April 6, 2014 Just up a couple jets on that carb...you will be fine! Hahahahahaha Quote
