ebay username sstarparts 2010
satts
Warning to all about sstarparts 2010 ebay username , watch buying roundhouse carriers from them they will send you the wrong size ,or bearings missing ,they sent me wrong size first then told me to send back at my expense ,did that then they sent me 40 mm one without bearings,then they told me i will have to deal with there supplier,bunch of fuckwits.
Yeah thats not prob 40 mm carrier use only 2 bearings one each side while 35 mm use 4 bearings 2 each side the carriers are differant if you buy a 35 mm carrier and try to put 40 m bearings in they pust to far thru and you cant use 2 on each side cause they stick out of carrier there thicker than 35 mm not just in diameter in short the 35 mm carrier in machined inside bout 5mm deeper to allow 2 bearings
