Are you running nitromethane? 60 pilots (and some orifices drilled) are the most you need to do to pwks in the pilot circuit for alky.
What's the size of the pilot jet orifice? If its not as big as the jet you're putting in a bigger jet may not help. If you check it let me know, because I don't remember. I know a guy that drills the pilots out something huge, but it makes them hard as hell to clean out.
Is it lean hanging at idle?
I've gotten away from PWKs and went to Lectrons on most motors.
I would be looking into an air leak if it needs that big of a pilot... Hell my 10dm only has a 55 in it... Sure ya got the slides low enough so that your actually using the pilot circuit and no drawing off the main/needle circuit? What needle are you running? What size main and dump?
