Joejr915 Posted November 15, 2012 Report Posted November 15, 2012 those guys running stock ignition for drag racing whats your setup? i thought about tring a stock ignition this year instead of pvl. i want to try a launch limiter. what for cdi(dyna msd or stocK),coil,stator flywheel(cut or uncut), And where do you guys get your adjustable clutch lever switch at? Quote
n2otoofast4u Posted November 15, 2012 Report Posted November 15, 2012 ALL OEM (you can use an AC coil but Im going to guess you wont need to worry about that) any OEM bike that has electric start will have a switched clutch lever. Ive used raptor and 450 levers. Quote
SlowerThanYou Posted November 15, 2012 Report Posted November 15, 2012 (edited) those guys running stock ignition for drag racing whats your setup? i thought about tring a stock ignition this year instead of pvl. i want to try a launch limiter. what for cdi(dyna msd or stocK),coil,stator flywheel(cut or uncut), And where do you guys get your adjustable clutch lever switch at? The adjustable is the only way to go. I think we got ours at MTC or Pingle can't remember. There's a certain way to adjust them for best 60'. If they get out of wack they cause all kinds of 60' issues (not good)! This subject will come up later in the lock-up/clutch tuning thread. Edited November 15, 2012 by SlowerThanYou Quote
Joejr915 Posted November 15, 2012 Author Report Posted November 15, 2012 i was tring to pm you slowerthanyou ur inbox is full , what setup do u use for ignition Quote
SlowerThanYou Posted November 16, 2012 Report Posted November 16, 2012 We use a programmable Dyna, but you can use a stock ignition with a Dyna DRL3000. I'll try & post the schematic. Quote
SlowerThanYou Posted November 16, 2012 Report Posted November 16, 2012 http://www.atvdraggers.com/forum//index.php?showtopic=2543 Quote
Paulie B Posted November 23, 2012 Report Posted November 23, 2012 http://www.atvdraggers.com/forum//index.php?showtopic=2543 So you simply wire it into you stock CDI. I hate to sound like a noob but which color wires do you use for a banshee? The pic is for a RM250? Quote
SlowerThanYou Posted November 23, 2012 Report Posted November 23, 2012 So you simply wire it into you stock CDI. I hate to sound like a noob but which color wires do you use for a banshee? The pic is for a RM250? Sorry, there are guys using this set-up on their Banshees with the stock cdi. I have no idea how to wire it for the Banshee. I guess I didn't pay attention to the diagram. I use a programmable dyna ignition with the launch limiter built in. Quote
Paulie B Posted November 23, 2012 Report Posted November 23, 2012 It looks like it goes to the kill switch (easy enugh) and one of the pick-up wires. So we have either white/red stripe or white/green stripe. Quote
SlowerThanYou Posted November 23, 2012 Report Posted November 23, 2012 It looks like it goes to the kill switch (easy enugh) and one of the pick-up wires. So we have either white/red stripe or white/green stripe. I would say call Dyna, but there customer service SUCKS! The couldn't tell me how to wire in their shift kill/counter to our banshee. After cussing me out, they had the balls to ask me how I wired it in. Quote
