Nightmare Posted September 3, 2012 Report Posted September 3, 2012 I picked up a 4mil last week and the seller said that it has a cut tranny(every other dog was removed). Can somebody please explain to me what the benefit is to this and is it a good set up for a 300ft dirt track? Quote
Nieskes Posted September 3, 2012 Report Posted September 3, 2012 I did this to mine, It helped alot over stock but it still does not compare to an override. I run 300ft and I only have to tap the clutch to get it to shift. Quote
trickedcarbine Posted September 3, 2012 Report Posted September 3, 2012 Pro mod, ez shift, ez cut..... Whatever we choose to call it will always be better then a stocker! However who cut it will make all the difference. Mine is the true Pro Mod from WCR and it is kick ass, but done by a douche! None the less I can ride it very aggressively and am able to ride it two different ways. Either blip the throttle and shift, or pin the throttle and just ever so slightly tap the clutch. I do either depending on what the bike is doing. I'm starting to get enough practice on it to shift it like an override on open straight situations to. But I can back load it all day engine braking after a down shift for big flat track turns, or long down hill sections. If a bike ever sees tight riding this is the way to go! Just make sure to accompany it with every shift mod you can minus the easy spring and get a good pancake bearing. Quote
Nightmare Posted September 4, 2012 Author Report Posted September 4, 2012 Pro mod, ez shift, ez cut..... Whatever we choose to call it will always be better then a stocker! However who cut it will make all the difference. Mine is the true Pro Mod from WCR and it is kick ass, but done by a douche! None the less I can ride it very aggressively and am able to ride it two different ways. Either blip the throttle and shift, or pin the throttle and just ever so slightly tap the clutch. I do either depending on what the bike is doing. I'm starting to get enough practice on it to shift it like an override on open straight situations to. But I can back load it all day engine braking after a down shift for big flat track turns, or long down hill sections. If a bike ever sees tight riding this is the way to go! Just make sure to accompany it with every shift mod you can minus the easy spring and get a good pancake bearing. So i can basically ride it like an over-ride on the track? Quote
Nieskes Posted September 4, 2012 Report Posted September 4, 2012 You will not be able to shift without the clutch on the track unless you let off, so no you will not. Quote
Nightmare Posted September 4, 2012 Author Report Posted September 4, 2012 I'll try it out and see what it does, thx for the input. Quote
trickedcarbine Posted September 11, 2012 Report Posted September 11, 2012 You will not be able to shift without the clutch on the track unless you let off, so no you will not. Like I said, depends who cut it..... I have really been hammering mine and just about got it down to shift mine like an over ride. Quote
Nightmare Posted September 11, 2012 Author Report Posted September 11, 2012 According to the guy I got it from it was cut by Tyson Sent from my SGH-T679 using Tapatalk 2 Quote
Nieskes Posted September 11, 2012 Report Posted September 11, 2012 Like I said, depends who cut it..... I have really been hammering mine and just about got it down to shift mine like an over ride. Lol its not rocket science to "cut" every other dog off even a schmuck like me was able to do it. Quote
camatv Posted September 11, 2012 Report Posted September 11, 2012 for them to work like tricked is describing takes way more than just wacking the dogs off. when it works right theyare very close in speed to an override. and at least 9 million times better than stock just like an override if it was just the drum done or just angle cut gears it wouldnt work. Quote
trickedcarbine Posted September 11, 2012 Report Posted September 11, 2012 Pow! No really it depends who cuts it! It really isnt rocket science, but there is a science to it. A good tranny will have more then just every other dog removed. You could lay my tranny next to a stocker and see that there are several things done to it if you know what you are looking at. Quote
Nieskes Posted September 11, 2012 Report Posted September 11, 2012 Read the first post,. Idk about you guys but im pretty sure all he said was his dogs were cut, then he asked if it would be like an override. Quote
Nightmare Posted September 11, 2012 Author Report Posted September 11, 2012 Yeah, it's just the dogs that were cut. the drum looks stock. I'm gonna run it this Friday and I'll report back how it is. Sent from my SGH-T679 using Tapatalk 2 Quote
trickedcarbine Posted September 12, 2012 Report Posted September 12, 2012 I have a Tyson stock style cut on my bench. There is more done to it hen just whacking every other dog. Also have one of his overrides on my bench, let's just say he brought a few of those tricks over to the stock style cut. Do you have a stocker next to it that you can compare every little detail. The faces or tips of the gears, the little locking nubs on the sides of the gears profiled, the shaft polished, the remaining dogs and cogs profiled? Just curious..... Tyson usually does more to them then just the dogs. That just seems to be the only part of the process people remember. You might have something way better then you think. RUN IT! Quote
