BLOODRAGE Posted May 18, 2012 Report Posted May 18, 2012 got the ss fired up for the first time, the pto side pipe gets hotter then the other.last time it fryed that piston now it seems like its trying to do the same.im thinking there must be an airleak just on the one side? Quote
zach45 Posted May 18, 2012 Report Posted May 18, 2012 Do a leak down? Sent from my iPhone using Tapatalk Quote
BLOODRAGE Posted May 18, 2012 Author Report Posted May 18, 2012 those are one of the tools ive been putting off to buy for far too long.think in order to save what i have in the motor id better buy one(leak down tester) Quote
zach45 Posted May 18, 2012 Report Posted May 18, 2012 Just make one... Shouldn't cost more then 20$ Sent from my iPhone using Tapatalk Quote
BLOODRAGE Posted May 18, 2012 Author Report Posted May 18, 2012 the thing that sux about making one is the town where i live doesnt have much of anything.but ill check around Quote
CFH87 Posted May 18, 2012 Report Posted May 18, 2012 CDI or coil could have something to do with it... My stock coil used to do that just fire on one side and warm one up while the other would fire on occasion. Quote
BLOODRAGE Posted May 18, 2012 Author Report Posted May 18, 2012 that could be the problem.it wouldnt start up until i got new plugs today.ill try and swap the plug wires and see what happens,thanks Quote
Nightmare Posted May 18, 2012 Report Posted May 18, 2012 CDI or coil could have something to do with it... My stock coil used to do that just fire on one side and warm one up while the other would fire on occasion. Mine was doing the same thing and turned out to be the coil Quote
BLOODRAGE Posted May 18, 2012 Author Report Posted May 18, 2012 just tryed it.does the same so it cant be the coil Quote
wacko2000 Posted May 18, 2012 Report Posted May 18, 2012 If you have already fried that side once, my opinion would be rule out the air leak first! If that checks out than start looking into your electrical system! Joe Quote
BLOODRAGE Posted May 18, 2012 Author Report Posted May 18, 2012 before i start tearing the intake boots off i have one question.could a stuck open reed cage be causing this problem?i did order a set of vforce 3 reeds but they havnt showed up yet Quote
