pematex > yamabond?
corypro
What's your personal preference?
It would be for putting the case back together
I would recommend the right stuff. Yamabond or somthing similar. If its red, blue, or black id avoid using it.
Which Permitex are you talking about. The only one I would ever consider is Permitex Moto Seal 1.
http://www.permatex.com/products/Automotive/automotive_gasketing/specialty_gasket_maker/MotoSeal_1_Ultimate_Gasket_Maker_Grey.htm
Permitex is a Brand not a name of a product. They make a couple hundred products so a little specification is in order.
For metal-to-metal bonds, like cases, I prefer ThreeBond 1211; for gasketed areas I prefer 1194. 1211 is more permanent and 1194 is semi-drying so if you apply a very thin coat to your gasketed areas it eliminates the possibility of gluing both sides of the gasket to the mating surfaces that can lead to the gasket splitting in the center. You definitely need to prep the surfaces before you apply any of these with some alcohol, contact cleaner, or similar.
Here is some sealant reference:
ThreeBond 1104 | Component:Synthetic Rubber | Color:Grey | Op_Temp:(-40°C to 150°C) | Dry_Time:5-min
  • Contains lead, Replaced by 1194
Hondabond #4 | Yamabond #4
ThreeBond 1194 | Component:Synthetic Rubber | Color:Grey | Op_Temp:(-40°C to 150°C) | Dry_Time:5-min
  • High padding property
  • It shows an excellent sealing effect not only on normal bonded surfaces, but also on bonded surfaces with large clearance
  • Excellent resistance to vibration and impact
  • After applied and dried, it will form a rubber-like elastic body and exhibit excellent resistance to vibration and impact
  • Excellent resistance to high and low temperatures
  • It keeps stable rubber elasticity in a wide temperature range from -40°C to 150°C
  • Excellent resistance to water and oil
  • Effective in preventing leak from threaded portions
  • Sealing of flange surfaces and threaded portions
  • Applicable to sealing of flange surfaces having large clearance
Suzuki Bond 1207B
ThreeBond 1207B | Component:Silicone Resin | Color:Black | Op_Temp:(-60°C to 200°C) | Dry_Time:7-min
  • Has high viscosity and excellent protuberance, and works effectively for the joint surfaces that have a larger clearance
  • Excellent engine-oil and LLC resistance
  • Dries quickly and offers excellent pressure resistance immediately after applying and assembling
  • Does not corrode copper and copperbased alloys
  • Cures even if it is left at high temperature of 120°C in uncured state
  • Note:Slightly difficult to remove
ThreeBond 1211 | Component:Silicone Resin | Color:White | Op_Temp:(-60°C to 200°C) | Dry_Time:90-min
  • Low viscosity, fluidic, and excellent workability
  • Can be used with solid gaskets and it can be used for temporary fixing of O rings
  • Corrodes copper and copper-based alloys. Can not be used for copper and copper-based alloys in tightly-sealed state
Hondabond HT
ThreeBond 1216E | Component:Silicone Resin | Color:Grey | Op_Temp:(-60°C to 200°C) | Dry_Time:6-min
  • Has excellent chemical resistance
  • Has high viscosity and excellent initial resistance to pressure
  • Has excellent resistance to heat and cold
  • Retains the elasticity of rubber in a wide range of temperatures, from -60 to 200°C or even, briefly, to 250°C
  • Used for sealing of surfaces such as those of oil pans of automobile engines, water pumps, and transmission cases
