have spark but cylinder still not firing
  • Please log in to reply
8 replies to this topic
#1 bansheeguy14
bansheeguy14
  • Members
  • Pip
  • 11 posts
Posted 19 February 2010 - 06:14 PM
I have a slight problem. I think that I know what the problem is but have not idea how to fix it. The left side cylinder(opposite the kick start, the choke side) is not firing. The cylinder is getting spark, but seems like it does not get any fuel to actually make the cylinder fire. When a new plug is put in and ran it looks like new when pulled back out. But when I pull out the choke about a quarter of the way out the cylinder starts to fire like it should, but then when the choke is released the cylinder quits firing. If you guys have any ideas about what I could check/repair then it would be greatly appreciated!
#2 jasons
jasons
    HQ Soldier
  • Members
  • PipPip
  • 756 posts
  • Gender:Male
Posted 19 February 2010 - 06:56 PM
clean your carbs make sure your jets are clean.
#3 bansheeguy14
bansheeguy14
  • Members
  • Pip
  • 11 posts
Posted 19 February 2010 - 07:04 PM
Forgot to mention that I have done that a couple times already. replaced the jets and took the carbs apart and vigorously cleaned them... I have done a lot of things that I thought it could be and still no result. Thanks for the comment tho maybe ill try it again .
#4 fastrthnu
fastrthnu
    HQ Captain
  • HQ Premium Member
  • PipPipPip
  • 2,316 posts
  • Gender:Male
  • Interests:going faster than you
Posted 20 February 2010 - 12:37 PM
if your jets are actually clean, maybe an air leak or stuck float.
#5 So Cal Suspension
So Cal Suspension
    HQ Commander In Chief
  • Members
  • PipPipPipPipPip
  • 5,072 posts
  • Gender:Male
Posted 20 February 2010 - 01:13 PM
Check the fuel line going to the left side carb and make sure it's still flowing fuel. Pull it off the carb, and open up the petcock and see if gas flows out. if not... well, there's your answer.
#6 bansheeguy14
bansheeguy14
  • Members
  • Pip
  • 11 posts
Posted 20 February 2010 - 02:23 PM
What is the easiest and most effective way to test for any air leaks? And what are the most common places to test for them?
#7 baker
baker
    HQ Soldier
  • Members
  • PipPip
  • 376 posts
  • Gender:Male
  • Interests:banshees beer boobs
Posted 20 February 2010 - 05:05 PM
this is just what came to my mind but check it, i put used carbs on my shee and it would only run on the right cylinder till i reved it about 10 times then the left would fire. i cleaned and cleaned many times then i read something about the choke jet, turns out the used carb bowl didnt have a choke jet in it! put on a different bowl with the choke jet in it problem solved! make sure you have the correct bowl on the left side and be sure there is a choke jet in it or clean the choke jet. just another option to try, good luck :cheers:
#8 AKheathen
AKheathen
  • HQ Premium Member
  • PipPipPipPipPip
  • 5,245 posts
  • Gender:Male
  • Interests:vagina....and shee
Posted 20 February 2010 - 06:00 PM
well, if it works with the choke, then the choke circuit, including the choke jet, is working. look for airleaks bu spraying carb cleaner around the intakes/reeds while it is running, and pry the carb around while you do it, to show any leaks better.....the idle will change when you spray a leak. if it doesn't show, since the cylinder isn't firing, then use some starting fluid or gas. check the float to see if it's moving right, and set right, and the pin is all the way in. did you remove the float needle/seat and make sure there is not junk in there? is the washer behind the main jet? that washer holds the emultion tube in place, and if it slides up a little, then the carb will only pull air around it, and really no fuel. you can see it pop up if you look through the filter side
#9 bansheeguy14
bansheeguy14
  • Members
  • Pip
  • 11 posts
Posted 21 February 2010 - 06:48 PM
Well guys I figured out what the deal was and it is running like a champ! I swapped out another set of carbs off of my other bike and bam fixed. So it must be something to do with that left side carb. Just wanted to thank everyone for their help! It was a huge help!
