Banshee HQ Forums: HELP! - Banshee HQ Forums
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
HELP!
#1 User is online   MIKE_XT
  • HQ Lieutenant
  • Pip
  • Group: Members
Posted 08 February 2010 - 10:40 AM
Hey guys,
I just jetted the banshee, but it didn't quite go according to plan. Mods are: Toomey T5's, K&N Filter, K&N Powerlid and VForce 3 Rad Valves. I used 280 mains, standard pilots and Toomey needles on the 4th clip from the blunt end, as advised by a few members of the HQ.
When I fired it up I had to give it a touch of revs to get it to idle and while puffing a little smoke from the right pipe it shot a flame. I was a little worried, and my brother suggested unburnt fuel. No worries, so I kick it over again and the same thing happens. I've heard that the smoke could be a result of the carbs not being synced properly, but the flames from the right pipe have me very concerned.
At this point I had had enough fun for the night. Have you guys got any ideas as to where I've gone wrong? I'm meant to be going on a trip in two days so I need to get this sorted ASAP. Any help/advice would be greatly appreciated!!
Cheers,
Mike
#2 User is offline   GrMeyer
  • HQ Soldier
  • PipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 08 February 2010 - 05:58 PM
Do you have the TORS kit?
Are the carbs Synced?
What pilots do you have?
Whats the Elevation?
Whats the Temp?
When was the last time the plugs were changed? I have had one that cracked and would only get spark every now and then.
Is the choke tube connected?
Read up on this site as well for help with jetting.
http://www.dfn.com/b...ren/jetfaq.html
98 Banshee with CPI Inframes, Dune Port, Noss cool head w/20cc, +4 timing, K&N Pods. 27.5pilot Needle 3rd and 320 Mains. G-Force +4 axle, Burgard +2+1 Arms with YFZ450 Shocks
05 660 Raptor with DMC Alien Exhaust, Hot cams stage 2, P&P head, SS valves, 11.1 Wiseco. Elka Dune shocks with Alba comp +2+1 arms. +6 Lonestar Axle. Trail Tech SCMR16 Lights
#3 User is online   MIKE_XT
  • HQ Lieutenant
  • Pip
  • Group: Members
Posted 08 February 2010 - 07:20 PM
TORS is still in place (ie. no TORS kit)
To the best of my ability, but I don't have the tool (will need to get one and do it)
I'm running the standard banshee pilots. The only thing I touched was the main jets, the needles and the air screws.
Elevation is roughly 6m above sea level (so basically sea level).
Temp is roughly 25-35 degrees celsius
Plugs are maybe a month old.
Choke tube and everything has been connected.
I hope something there helps. And sorry for the metric measurements.
This post has been edited by MIKE_XT: 08 February 2010 - 07:22 PM
#4 User is offline   firebanshee
  • HQ Soldier
  • Icon
  • Group: HQ Premium Member
  • Gender:Male
Posted 08 February 2010 - 09:23 PM
Did you accidentally swap the slides? :blink:
Posted Image
93 banshee 4mil long rod welded crank tz bearing(BROKE CONNECTING ROD)
68mil cub on alky redline port job 21cc dome
stuffed and ported cases +10 timing stock ign
39 pwk alky carbs 14 inch k&n filters v force 2 reeds
wicked big bore right side exit out of frame pipes
2-5 dunable override lockup clutch billet basket
12 inch metal tech link style round housing swing arm
JJ&A gun drilled rear drag axle and carrier
+1 forward metal tech chrome a arms
marvin shaw shocks front and rear
22x8 12 paddel extreem 72 inch rollout rear tires
MY EBAY FEEDBACK RATING
having redline racing build a new 558cc 10mil cheetah with a billet twister crank
#5 User is offline   GrMeyer
  • HQ Soldier
  • PipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 10 February 2010 - 09:41 PM
Do you still have the stock needles?
Do you have 27.5 pilots
If it was me. I would put the 27.5 pilots in. Pull the power lid. Put the 280s back in. Turn the air screw 1-1/2 turns from fully closed. Make sure the carbs are really clean. But I also think that your mains might be running lean with the temps being cold and all. But remember when Jetting. Set the main first. Then the needle, then the pilot-air screw.
#6 User is offline   Burt Reynolds
  • HQ Lieutenant
  • Icon
Posted 12 February 2010 - 01:01 AM
You should be close with that jetting.If anything i would say go one step up on the pilot. But i wouldnt think a stock pilot would be that far off. I ran t5's with clamp on KnN's with stock pilots and 280 mains,needle in the middle,and it ran great
Page 1 of 1
