NOS_350x Posted December 18, 2009 Report Posted December 18, 2009 It didnt take me too long to pick it up. Ice Speedway came into town and Hoosier gave me a set of there new nobbies to run. Won both my heats that night, Was on the pole for the main. On the start i got the holeshot with a good lead. Came around and the race was redflagged. In the restart i lost 1 cyl, Got 5th with a 1 cyl shee. Quote
TwistedSheeRida Posted December 18, 2009 Report Posted December 18, 2009 thats what im talking about! owned that shit. Those were some badass holeshots. Quote
motodrumer58 Posted December 18, 2009 Report Posted December 18, 2009 Right on Bro...... You got to let me know your tire and stud set up. I would give my left nut to pull off the line like that!!!! I want to do what you did to the 4 strokes here in Michigan Quote
TwistedSheeRida Posted December 18, 2009 Report Posted December 18, 2009 http://www.brunowessel.com/catalog/index.asp?display=all&categoryid=1 these are what you want to run for studs. they dont pull out carbide tipped and you can run them in the dirt. Quote
motodrumer58 Posted December 19, 2009 Report Posted December 19, 2009 http://www.brunowessel.com/catalog/index.asp?display=all&categoryid=1 these are what you want to run for studs. they dont pull out carbide tipped and you can run them in the dirt. Quote
motodrumer58 Posted December 19, 2009 Report Posted December 19, 2009 The studs will be an unaltered #7 to #10 hex headed screw with no more than one slot, uncut, no drilling or hollowing out of the head and the screw to be flush into the tire tightly ,not using a shim or washer to hold it out from the tire. The screw head cannot exceed 3/16” above the tire. This is the rules for ama d14 I am using kold kutters Quote
NOS_350x Posted December 21, 2009 Author Report Posted December 21, 2009 (edited) Ok, Im Going to try and add as many answers to the questions here as i can If you have more questions or i didnt answer soemthing please ask again. This was an ICESpeedway.com even We can only use studs purchased from them, They are Kold Kutters or something like that. I got them 5/8" long so they wouldn't go through the tire and if i wanted i could remove them and run the tire in the dirt. I have to give all the credit on the holeshot to the Hoosier tires and the stud pattern. Tomorrow I can get you pictures of the stud pattern I used. I spend alot of time thinking about the best way i could get the most traction the design i came up with is what i think is the best. Also just about everyone i raced with ran Turf tamers, I think i have a better pattern in my head for those too. BUT im not going to let that one out, The pattern for the Hoosiers ill show yall. Another thing that helped alot was tire pressure, ALOT of the guys there went checking it, but i noticed big differences in different pressures, my tire pressures where 6, 8, and 10 PSI, You can figure out what tires had what pressure in them. Now i got a pm about the suspension, Im going to answer it in here. I'm trying to get the shee set up for flat track/tt/ice style but am having a hard time finding a correct shock setup. every one keeps saying r6, or 300ex, but they would be to low and eliminate the proper weight transfer I think a shee needs. I know its gotta be lower, but not too low. Can I ask what shocks you use and where to get a similar set, you seem to be one of the only riders who communicates setup who has a bike that seems fairly close to what I'm lookin to build. I have Triple Rate PEP shocks on my shee. I agree with you, You dont want to be too low, or too stiff you are loosing a TON of traction by doing both those things. The first 2 nights of the ICE racing i used my full 1/8mile dirt setup. It was hooking too early in the turns and pulling me towards the wall, So i dropped my ride height 2" from that setup. I left the LR weight at +20 LBS. The shocks are just a very good adjustable STD length shock. If i crank the spring adjusters all the way down i can jump and stuff but when i want to flattrack i get about 4-5 inches of down travel and 4 inches of up travel. IMO this is key to get the traction needed with the powerband of the shee, and the Uptravel helps when in a wheelie like situation getting on the gas you can still control and turn. BTW, This weekend i did 2 more races after a 1800 mile drive. 4th ice race ever for me and i got 1st, the second night i got 4th starting in the 3rd row after jumping the start. More pics and videos tomorrow. Edited December 21, 2009 by NOS_350x Quote
locogato11283 Posted December 21, 2009 Report Posted December 21, 2009 nice job bro. those fuckin 4 pokes didnt stand a chance against the banshee. its too bad that track isnt a little bigger so you could really open it up and walk away from the rest of the pack. Quote
KEVSWS6 Posted December 21, 2009 Report Posted December 21, 2009 Talk about a short track. Show them 4 strokers how to 2 stroke it! Quote
NOS_350x Posted December 22, 2009 Author Report Posted December 22, 2009 there is the stud pattern for ya. There is my main event win. Quote
motodrumer58 Posted December 22, 2009 Report Posted December 22, 2009 I just watched the viddy. That was cool as hell. My vote for banshee video of the year!!!! Hats off to ya.. thanx Quote
motodrumer58 Posted December 22, 2009 Report Posted December 22, 2009 Were you limited to the number of studs you could use? thanks Quote
NOS_350x Posted December 23, 2009 Author Report Posted December 23, 2009 Were you limited to the number of studs you could use? thanks We can use an unliminted amount of studs. Before the race i was told i would need nearly 2000 studs to be competitive. Im around 1200 studs. Front and rear. I guess maby if i added more the other guys could keep up then. Quote
Ieat4strokes Posted December 24, 2009 Report Posted December 24, 2009 fuccin sick! second video was the best holshot ive ever seen on ice lol, gutsy move and you pulled it off.....Hats off to ya man! Quote
