Powerstroke Posted April 7, 2009 Report Share Posted April 7, 2009 I just put YFZ calipers on my banshee and thought I would do a brake bleeding how to. The method I like to use is super simple and waste very little fluid. 1st remove your bleeder screws and wrap the threads in teflon plumbers tape. This stops small leaks from around the threads while your bleeding the system. 2nd you will need a piece of clear hose that fits on the bleeder good and tight. Go ahead and open the bleeder now. 3rd place the end of the hose into the master cyl. and pump the lever until all the air bublles are gone. A couple notes I had enough hose to do both sides at once. You can do one side at a time also. Once all the air is out of the hoses close the bleeders, top off the master cyl. and clean up its that simple. Quote Link to comment Share on other sites More sharing options...
04chase Posted April 7, 2009 Report Share Posted April 7, 2009 very good way to do it , only thing is it does creat small air bubbles in the master and they take time to float to the top and pop . i did the redneck way this weekend , fill the master, and attach a hose and suck on it until most of the air comes out and just bleed from there. but the way above is how i always bench bleed masters . Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted April 7, 2009 Report Share Posted April 7, 2009 Cool trick! I put the 450 brakes on mine and just gravity bled them. They are MUCH easier to bleed than the stock banshee brakes. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted April 9, 2009 Report Share Posted April 9, 2009 so i take it, the 450 calipers are a direct bolt up to the banshee spindles? Quote Link to comment Share on other sites More sharing options...
1996dragshee Posted April 9, 2009 Report Share Posted April 9, 2009 hmm maybe i should do this.I raced all winter on the ice 660' track with no brakes...i figured i had long enough of a shut down lol Quote Link to comment Share on other sites More sharing options...
Powerstroke Posted April 9, 2009 Author Report Share Posted April 9, 2009 so i take it, the 450 calipers are a direct bolt up to the banshee spindles? Yep direct bolt up. I did have to remove the inner shields. They would have to be trimmed if you wanted to use them. Quote Link to comment Share on other sites More sharing options...
