how do i put on a kill switch?
  • Please log in to reply
4 replies to this topic
#1 tommilo
tommilo
  • Members
  • Pip
  • 5 posts
Posted 12 October 2008 - 03:15 PM
i bought a 88 banshee and it does not have a kill switch well the one on the left bar os not hooked up. what wires do i use to connect a kill switch? any info great. thanks
#2 Mat Holland
Mat Holland
    HQ Soldier
  • Members
  • PipPip
  • 165 posts
Posted 12 October 2008 - 03:48 PM
I have the same issue, mine has no key the kill switch is on the handlebar, but its in with some wires, and I don't know how they have it wired. Any ideas? Not hijacking your thread, but I have the same problem, just thought I would throw it out there.
#3 flea49
flea49
    HQ Soldier
  • Members
  • PipPip
  • 313 posts
  • Interests:working on shees lifting weights
Posted 12 October 2008 - 03:54 PM
Black wire grounded to bare spot on frame,Red wire sliced into orange wire going to coil.
#4 jbooker82
jbooker82
    HQ Commander In Chief
  • Members
  • PipPipPipPipPip
  • 6,380 posts
  • Gender:Male
Posted 13 October 2008 - 12:10 AM
That is hard on CDI's. Dyna FS says not to do it that way. Hook the ground wire of the teather to the black wire that goes in to the handle bar kill switch. Hook the other wire to the Black wire with White stripe. This is how the stock kill switch works. When you ground the black/white wire to the black wire it kills the engine.
http://www.dynaonlin...ek_faq.aspx#610
How do I properly wire a tether kill switch?
Most tether kill switches sold are normally open with the tether key installed. Once the tether key is removed, the switch will close itself, creating a short to whatever circuit it wired to. This should not be used to ground the high voltage signal to the ignition coil.
WARNING: Installation of a grounded tether kill switch to the ignition coil signal will damage the ignition. Consult your individual instruction manual for specific wiring instructions.
RECOMMENDED: Magneto- Source coil CDI (Banshee / 400EX / 250R / MX bikes / etc): Use a NORMALY OPEN tether kill switch connected to the stock kill switch. When tether is removed the switch should ground the kill input into the ignition.
12V DC-CDI (Raptor / Z400 / KFX400 / ETC): Use a NORMALLY CLOSED tether kill switch connected in series with the +12V input to the ignition. When the tether is removed, it should disconnect the +12V power to the ignition. Most battery equipped quads have a RUN/STOP switch which disconnects +12V power, a NORMALLY CLOSED tether switch can be installed in series of these wires.
#5 KaosBanshee44
KaosBanshee44
  • Members
  • PipPipPipPipPip
  • 5,282 posts
  • Gender:Male
  • Interests:Beer, Women, and Banshees
Posted 13 October 2008 - 01:38 AM
Exactly and just make sure you have a good ground, if you have to grind off some of the powdercoat on the frame do it or you'll run into problems.
