gas question octane
#1
Posted 12 September 2008 - 07:38 AM
I run 89 and was wondering if I may be missing out on some performance/running advantages.
I mean the bike runs really good now that I got it jetted.
If I do switch will the jetting be effected?
Wicked +2+1 arms, Works dual rates, Pro Taper SE bars, stainless brake lines, Terry Cable throttle, 30mm OKO carbs, Pro Flow filter, PTR mids, Hot Rod crank, LSR axle with all Boss hubs, ITP Baja rims with Razr tires...for now
#2
Posted 12 September 2008 - 07:53 AM
Depends on the mods you have done to your bike, might not feel it but it’s a cheap insurance for a healthy banshee .
I would recommend using the premium pump gas all the time. and for 2 stroke oil I use castor 929 in all my bikes , never had a problem. (and use a measuring cup when measuring oil)
THE GARAGE ...
2008 Indianapolis Dealer Trade Show Banshee/Trinity ....
SILIVER BULLET Banshee/ SPEEDFREAKS RACING....
2001 BANSHEE / SPEEDFREAKS RACING..
2005 YFZ 450 ..
visit my myspace page ---> http://www.myspace.com/423980374
If your intrested in this bike Email me infinitied@aol.com
#3
Posted 12 September 2008 - 08:18 AM
I run Amsoil Dominator at about 60:1 and dont plan on changing.
I know if you increase the compression then you would need a higher octane so would running 93 help the bike start/run better?
#4
Posted 12 September 2008 - 08:42 AM
why 60:1?
-Toomey T-5s.
-Pro design foam filter kit.
-MSR dominator handlebars.
-MSR AOF clutch lever and purch.
-Billet Case saver.
-Cometic gaskits.
-FMF Pipe o-rings and springs.
-Motion pro T.O.R.S eliminator.
-Motion pro clutch cable.
-Lonestar parking brake block off.
-Raptor front tires.
-Gator tires mounted on Raptor rims (+2).
-Skids all around.
-Billet handlebar clamp.
-Stainless steel clutch & stator bolts.
-Purple In-line water cooler (Purple power!).
-Stiffer Clutch springs.
-Pro design mega-flow billet impeller.
-Some bling-age.
http://www.bansheehq...showtopic=85240
#5
Posted 12 September 2008 - 08:52 AM
burn slower and more efficiently. By doing this, they help avoid detonation or knock/ping. If you
are running 89 oct, and your engine is not knocking or pinging then you should be fine. For the
few extra cents you may want to just use 93 oct becuase is does burn cleaner as in efficient and
maybe "maybe" get a bit more life and efficiency/power out of your engine and parts. But I do
know guys that run 89 with no problems... Also bumping up octane should not effect your jetting.
If you advance the timing or compression you would want to consider higher octane fuels.
This post has been edited by mdhc500: 12 September 2008 - 08:54 AM
A 1987 J-Arm frame, stock 2006 motor, FMF Fatty Pipes & Silencers-Ceramic Coated Flat Black, Boysen
Reeds in the stock cages, K&N filter, Vito's Hemi Head w/19cc domes @155+ psi, ITP Holeshot HD's all
the way round on ITP .190 polished wheels, 2000 white plastics kit, AC Propeg NERF's, Renthal Bars
& Grips... More to come soon!
#6
Posted 12 September 2008 - 08:53 AM
I run Klotz R50 with 93oct (40:1) and it runs awesome....I recommend that you always run 93 if I was you.
Klotz R50 Racing TechniPlate(Reference #KL-105)
100% synthetic lubricant developed exclusively for use in Hi-RPM 2-stroke racing engines. TechniPlate R racing lubricity system protects engines from extreme heat and virtually eliminates engine wear. R50 film strength is comparable to castor oil with the benefits of Clean Burn technology.
Klotz recommendation: ATV: Water cooled mix at 40:1, Air cooled engines mix at 32:1
And it smells awesome....
- Loaded and ready for the next ride...
#7
Posted 12 September 2008 - 09:21 AM
i agree with this reply 100% ,
also 60 to 1 ? 40 to 1 or 32 to 1 would be right for you.
and if you ever increase your compression or adj timing you will def need to increase the octane.
your bike could be pinging and you will never hear it over the pipes !
THE GARAGE ...
2005 YFZ 450 ..
#8
Posted 12 September 2008 - 10:29 AM
One of the guys I raced MX with worked in Evinrude's product develpment department and would give a great rundown on the myths of two stroke mixing ratios. In test after test the best mix they came up with even with synthetic oil was 28:1 with 112 octane fuel. Octane rating has no bearing on the ratio for mixing but their is a myth that lower than 32:1 is too much oil, but too little fuel can blow the pistion. You can't over lubricate a two stroke. The oil is designed to seperate into the crankcase for proper lubrication when the reeds do their air/fuel mixing. The only benefit to running 40:1 is that you use less oil and it is easier on the wallet. Evinrude's official fuel was Cam2 with BelRay H1R. (not my favorite oil by any means) Nowadays he runs VP C12 and since then I switched also to VP when I can afford it. Today's synthetic oils are a lot more advanced but the theory is the same. The main benefit to running 32:1 is when breaking in a new top end the rings seat better. Can you run 40:1 and have the motor last? Yes, you can provided you jetted the machine with a 40:1 mix. Since most of us don't own 50K dollar racing engines we aren't as vulnerable to the kind of damage a high compression two stroke motor is.
Basically I was told to have your machine dynotuned for jetting and use the ratios from that point on as "The Gospel". Example: You put on pipes and higher compression domes for your rod and you have the machine dyno tuned with 50:1 mix, you can't just decide on a whim to go to 32:1 mix because now you are leaner on fuel and this will cause problems. At Evinrude the machines were dynotuned at 28:1 so the variable could be as high as 32:1 or as low as 20:1 with out damage due to a lean condition. HAVE YOUR MACHINE DYNOTUNED PROFESSIONALLY FOR THE RATIO YOU LIKE TO RUN AND YOU WON"T GET HURT.
Detonation is a real problem with two strokes that many people aren't aware of. Their is a world of difference in a two stroke having 9:1 compression and a four stroke with the same ratio. The two stroke is more easily damaged from detonation and needs fuel with a higher flash point. Avoid 93 octane if you can help it. It is killing your motor. Like it or not you need race fuel for that thing.
However read this post on another website for some good info on the proper mixing ratios:
Two Stroke Mixing by someone who knows what he is talking about
I agree with the Klotz post: That oil is by far the sweetest smelling oil when it burns and I love getting behind someone when they are using it. My preference is Yamalube. I never foul a plug with it and you can buy it by the gallon for around 20 bucks.
This post has been edited by RollinRhino: 12 September 2008 - 10:31 AM
#9
Posted 12 September 2008 - 10:38 AM
A good point in all this is this: If you change your pre-mix ratio you may need to adjust your jetting.
Good to point that out. I do disagree that a "stock" banshee for the most part is 100% om on 93 Oct.
I would say race fuel would be a bit of a waste. But to each his own... It cant hurt and smells good!
#10
Posted 12 September 2008 - 12:02 PM
I run the Amsoil at 60:1 because at 50:1 (what the bottle recomends) I was getting wet/black plugs. Since then I have rejetted at the same mix 60:1 and it runs really good.
I think I will try the 93 on the next tank. I am going to the Rumble On The Ridge next weekend and wanted to check this out before I went.
So if I bump the timing +4 will the 93 still be OK?
#11
Posted 12 September 2008 - 12:32 PM
be ready for a melt down sooner or later with that ratio. might be ok for light trail riding , but if you start opening it up it will not be enough ! best of luck ,
but dont beleive everything you read on bottles.
f.u.i. --> so you know black and wet plugs are not from your ratio, its because your bike is too rich , not because your running to much oil !!
if almost everyone is using 32 to or richer why would you think 60 to 1 is ok? (thats a wead wacker ratio)
THE GARAGE ...
2005 YFZ 450 ..
#12
Posted 12 September 2008 - 12:53 PM
93 oct on +4... I'd keep an eye on it. Also I agree 60:1 even with a good synthetic oil??? I wouldnt
risk it... I personally run 32:1 and am jetted accordingly...
#13
Posted 12 September 2008 - 01:39 PM
This post has been edited by boneyardbanshee.: 12 September 2008 - 01:43 PM
#14
Posted 12 September 2008 - 01:55 PM
boneyardbanshee., on Sep 12 2008, 01:39 PM, said:
rejet and go 40 to 1 and you will be good to go ..
THE GARAGE ...
2005 YFZ 450 ..
#15
Posted 13 September 2008 - 01:56 PM
boneyardbanshee., on Sep 12 2008, 02:39 PM, said:
jeff at F.A.S.T has all the jets you need
Thanks to F.A.S.T for the power
if everything seems under control your just not going fast enough!!
Sign In
Register
Help
Back to top
MultiQuote
