421 serval jetting + carb issue
KAMIKAZE
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
Tried swapping leads again and fitted a brand new coil
No change
When you pull a lead off each cyl it sounds like the right side is firing half as much as the left
This doesn't change when you swap leads to other side
About to swap carbs and see what happens
I did a leak down and it was up the shit
Pulled intakes apart re did everything dropped from 6psi to 5.5psi over 10 mins is that ok ?
Idles a bit higher now seems better but will have to wait til tomorrow to test as not enough room out the front
Still doesn't seem to have the go it should though
