421 serval jetting + carb issue
KAMIKAZE
Kamikaze...im pretty positive that your are chasing a carb sync issue. Ive been there and done that. Take your time and set the carbs correctly and you should notice the change. That serval will impress you. I run a +6 swinger and when the tires hook, the front end will point to the sky. 2 jet sizes in the wrong direction will make it feek weak. When its spot on, you will knowm
  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
Cheers bud I'll keep playing with it ATM it won't lift the wheels on the road and I have stock swing arm
Ive got some more plugs and jets will keep at it just feels like it falls off on the top end
Not sure if I mentioned I have cel needle middle clip and air screw 2 turns out
