Yup another Alky Plug photo :)
troyzstang
Ok Guys . Here's a quick Alky plug test for you.
These plugs have never seen purge gas and have a days worth of 300ft runs on them. ( 5 runs)
Specs
10 mil on alky
40mm lectrons
Same side CPIs
+ 10 advanced timing.
Opinions please
Thanks
Troy
i wouldnt say so. typically one cylinder will need more fuel than the other. i always get the bike up to temp make a few hard passes and pull them. within 3 passes if "close" you should be able to see a 10 and 3 burn ring and a mid arch timing purple band. i was always 1-2 full turns further out on typically the stator side. it burns hotter for some reason.
if there is no real reason to get all the power you can i normally started rich and leaned it down until it started making decent power and left it rich. lot easier on parts.
  • Like 1
