Loosechange19 Posted April 16, 2014 Report Share Posted April 16, 2014 2006 stock motor banshee. Just ordered the following Cpi inframes V force4 reeds Adjustable timing Stock airbox. Probably going to order a uni filter or something like that. Nothing fancy Elevation +640 Need somewhere to start on jetting Thanks Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted April 16, 2014 Report Share Posted April 16, 2014 This is just a WAG. needles middle clip 27.5 pilots 280 mains 1.5 turns out on the airscrews from fully seated. Do Not Over Tighten the airscrews! Just seat them, take note of the screw head slot and turn them out 1.5 turns. They should be the same. Do you still have TORS? Make sure your carb slides are sync'd. The bottom end is going to suck with CPI In Frame Drag Pipes. You will have to slip the clutch more to keep the stock port motor on the pipe. I can't imagine you're riding trails with this pipe set-up, but stranger things have happened. If you are riding dirty/muddy wet areas? Do you plan on keeping the airbox and lid? If so, get the Pro-Design billet intake kit that fits in the airbox and allows you to replace that stock POS stock filter set-up with a K&N Filter and an Outer Wear. http://www.farmandsandtoys.com/partdetail.asp?partid=457 If you do not ride in dirty/muddy areas, then get two K&N Filters and Outer Weasrs for the stock carbs and remove the entire airbox entirely. http://www.farmandsandtoys.com/partdetail.asp?partid=330 Quote Link to comment Share on other sites More sharing options...
Loosechange19 Posted April 16, 2014 Author Report Share Posted April 16, 2014 Bike is 100% stock right now. Got the cpi because when top end goes it will get porting. Still has tors aswell Quote Link to comment Share on other sites More sharing options...
Uf21 Posted May 6, 2014 Report Share Posted May 6, 2014 Quote Link to comment Share on other sites More sharing options...
Loosechange19 Posted May 12, 2014 Author Report Share Posted May 12, 2014 well i did the install today cpi small bores vforce 4's uni drop in 290 mains 27.5 pilots as someone mentioned, the bottom end is sluggish but it pulls like a raped ape in powerband idle is perfect as well would changing anything on the mains help me with the low end, i have 310's i could slap in real quick i understand the pipes are killing me but why not ask Quote Link to comment Share on other sites More sharing options...
Strm Trpr Posted May 12, 2014 Report Share Posted May 12, 2014 Main jet affects 3/4 to WOT. There's nothing you can do but live with your decision. Quote Link to comment Share on other sites More sharing options...
Loosechange19 Posted May 12, 2014 Author Report Share Posted May 12, 2014 No worries, just trying to learn here I understand these pipes aren't designed for what I'm doing I have not moved the needle yet ethier Would that or is that still necessity? I'm okay with it as it is really I also have a +4 timing plate I need to install, maybe that'll do something Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted May 12, 2014 Report Share Posted May 12, 2014 Richen up that needle position Quote Link to comment Share on other sites More sharing options...
Loosechange19 Posted May 12, 2014 Author Report Share Posted May 12, 2014 Will do I'll do the middle one that storm trooper suggested Quote Link to comment Share on other sites More sharing options...
Loosechange19 Posted May 12, 2014 Author Report Share Posted May 12, 2014 Thanks for the responses too Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 13, 2014 Report Share Posted May 13, 2014 The timing will get you some bottom end back. Also, a new head and domes will help liven it up a bit. Maybe have a stock head milled and re chambered by mull. Just order a used one online and drop ship it Quote Link to comment Share on other sites More sharing options...
Uf21 Posted May 14, 2014 Report Share Posted May 14, 2014 The timing will get you some bottom end back. Also, a new head and domes will help liven it up a bit. Maybe have a stock head milled and re chambered by mull. Just order a used one online and drop ship it I always read different thing regarding timing plate. Some say it will give more top end and others say it will give more bottom. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted May 15, 2014 Report Share Posted May 15, 2014 ^ timing gets the bike low end. Excessive timing up top makes the motor fight itself and won't rev out as well. This is why guys with programmable ignitions set up curves with heavy advance early on, and then retard the timing further up in the revs. Quote Link to comment Share on other sites More sharing options...
Uf21 Posted May 15, 2014 Report Share Posted May 15, 2014 ^ timing gets the bike low end. Excessive timing up top makes the motor fight itself and won't rev out as well. This is why guys with programmable ignitions set up curves with heavy advance early on, and then retard the timing further up in the revs. So does adding a timing plate sacrifice top end? Quote Link to comment Share on other sites More sharing options...
