Dune/Drag 10mm Serval Part out
 Serval Cub. Prices are fair/firm. I will pay shipping, you pay the fees or gift it. Up to you.
10mil Serval Cub Cylinders - $950
  • 4 Arp 12pt nuts
  • 4 12mm head nuts
  • Stud extenders
  • Gas domes (Wildcard)
  • Pistons
10mil Crankworks Billet Crank - $750
Banshee Cases, Trenched, Port Matched and epoxied for more gasket surface, excellent condition - $350
  • Billet Neutral switch plate
Duneable 1-5 N-down, Tyson Transmission - $350
  • Drum
  • Shift Forks
  • Shift Fork Rod
Direct Drive Lock-out, Lock-out Cover, Billet anodized dip stick, Chariot EZ drain, Billet Impeller, Chariot cover, Cascade blank off plate and breather blank - $350
VF3 Reeds - $125
Billet basket, FAST clutch/plates, Chariot pancake bearing, OEM hubs - $225
Packard Lectron 40/40mm Gasoline Carbs - $550
  • Packard Bowls
  • Chariot billet intakes
  • 8” Filters with outerwears
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0350.jpg
Chariot Billet Bearing Support Cover - $250
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0299.jpg
Stock Transmission - $100
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0361.jpg
Round Plug Stator w/Pro-Design adjustable timing plate - $125
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0314.jpg
Flywheel - $100
  • No Damage, excellent condition
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0336.jpg
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0337.jpg
Richies Pegs - $100
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0358.jpg
Direct Drive Spindle Mounts (Banshee) $400
  • 10x4 Triple Buffed
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0374.jpg
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0376.jpg
JJ&A Polished Axle $500
  • Banshee sprocket
  • Boss 40mm Carrier (Polished)
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0368.jpg
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0370.jpg
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0371.jpg
Marvin Shaw 13” - $225
http://i1140.photobucket.com/albums/n575/acg1977/Banshee%20Parts%20-%20Part%20out/SAM_0373.jpg
Excellent seller here guys. Most parts are NEW or like new.
I know because this Build / parts were bought while Adam was on deployment overseas.
Parts kept showing up on my doorstep and filling up my spare bedroom.
*** BUY WITH CONFIDENCE ***
Troy
Edited by troyzstang
The Serval Cub cylinders are 68mm bore. It has pump gas domes. I do not know the hp of the motor. it was not dyno'd. I can tell you, according to the butt dyno, it has more hp/tq than a stock motor. Other than that I am clueless as to numbers. If a 4mil Serval claims 80hp, this has more than that? Im not going to make up some arbitrary number to sell these parts to anyone. I built the motor I wanted at the time because there were not many around. Brandon and I never discussed numbers in that sense.
Adam
  • Like 1
  • 4 Arp 12pt nuts
  • 4 12mm head nuts
  • Stud extenders
  • Pistons
  • Drum
  • Shift Forks
  • Shift Fork Rod
VF3 Reeds - $125
  • Packard Bowls
Flywheel - $100
Richies Pegs - $100
  • Banshee sprocket
Do you know won made the billet clutch basket, also what condition is the clutch in? Also how are the hub and pressure plate?
Thanks
Tyler
Buy with confidence!!
Great seller and dam man you sure do ship fast i was not expecting it till next week thanks again man!!
Yeah Adam's a great seller.
But they only shipped quickly because I spent four hours helping him pack this shit up.
Crazy fucker. Spends almost two years collecting parts and cluttering up my work bench just to turn around and sell it at a loss.
And to top it off. Now he's talking shit about building another one and trying to run me down.  Whatever. :)
  • Like 2
