lean hangs
djackbanshee
On alky ...
Whenever it get to the end of the 1/8 miles when I let the throttle off it hangs and then on the return lane whenever I blip it it kinda hangs . It runs fine blipping the throttle at the start some alky spitting from the pipes , Got the billets bowls . Would it be the pilot jet ? Needle diameter, clip position ?
Got the floats figured out billet bowls had to have the brass overflow tube tweeked a little higher to match stock ones .... also just seen I was given M5 by mistake .. Anybody used that stuff???
Were the chariot bowls? Those are usually close, but sometimes you gotta bend them. Hold both ends so you don't crack the braze.
