Massive TRX450R Parts Sale - Stock and Aftermarket
ghott
I have a bunch of parts that I need to sell.  These parts are a mixture of parts taken from the stock bike that I tore down to turn into a drag bike and parts that I've had in storage for quite a while.  Most of these parts are for 04/05 Honda TRX450R's but some will work on many different quads.
First and foremost - the prices do NOT include shipping and do NOT include PP fees.  Buyer will cover the PP fees or can gift the payment to save the hastle.  Shipping will be anywhere from $2 to $95 depending on the part's size and weight.  The prices listed are for local pickup only...which is preferred for the larger/heavier items.
I like to take a lot of pictures of items I put up for sale so there are no surprises for buyers.  I have a total of 194 pictures for the items below; that's way too many to post in a thread...so I just uploaded them all to a photobucket gallery.  See the link below for all the pictures.
Detailed pictures of all items here:
http://s288.photobucket.com/user/ghott01/library/fall2013sale
Some of this stuff...I don't really know what it's worth; so feel free to offer.
- OEM 04/05 Exhaust Header Pipe - $10
   -- Dirty and rusty but worked well in conjunction with the FMF silencer listed below
- OEM 04/05 Ignition - $20
   -- Works great, just dirty
- OEM 04/05 Coil and Spark Plug Cap - SOLD
   -- Bought this a few weeks ago but didn't need it
   -- Works well and in great shape
- OEM 04/05 Crank and Bearings - $20
   -- This is the original crank from my '05
   -- No clue if it's still in spec?
- OEM 04/05 94mm Cylinder - $10
- OEM 04/05 Oil Cooler (w/ lines, o-rings, shroud, and mounting bolts) - $35
- OEM 04/05 Kicker w/ Joint and Bolt - $55
- OEM 04/05 Top Motor Mounts (complete with bolts) - $15
- OEM 04/05 Swing Arm Pivot Bolt - $5
- OEM 04/05 Radiator w/ Cap - $25
   -- She's dirty and has many bent fins; also dented on top-right side; no leaks
- OEM 04/05 Stator w/ Gasket - $65
   -- Works well and is in good shape
- OEM 04/05 42mm Keihin Carb - SOLD
   -- right side cover bolt was stripped - oversized screw holds it on though
   -- has silver spray paint over-spray on it
- OEM 04/05 Intake Boot w/ Clamps - $10
   -- Has some sort of custom resonator plug
   -- Has silver spray paint over-spray on it
- OEM 04/05 94mm Piston w/ Pin and Rings - $5
   -- No clue if this is in spec or not?
- OEM 04/05 Cylinder Head Valve Train Parts - $5
   -- No clue if any of this stuff is any good
   -- All valves, springs, keepers, etc. pulled from a stock 04/05 head
- OEM 04/05 Cam Chain Tensioner w/ Gasket & Screw - $15
   -- Great shape, pulled from my 522 engine for a manual tensioner
- OEM 04/05 Valve Cover w/ Gasket - $15
   -- Great shape, painted black, some wear marks, pulled from my 522 for an OEM colored cover
- 04/05 Stock Kicker Engine - $900
   -- Sold as-is...I don't know much about it, but it ran very well directly before removal and had great power (see videos below)
   -- Shifted well under load - no clutch slipping
   -- Little dirty but should clean up well
   -- Has what looks to be gasket sealer around valve cover
   -- Top case saver hole is cracked (doesn't leak and still holds a bolt well)
   -- Shifter shaft looks like it got knicked by the chain (still seems straight tho)
   -- Doesn't include t-stat, t-stat cover, shifter, front sprocket, or kicker
   -- Videos below were taken last weekend (weekend before the engine was pulled)
      -- Cold start video:
      -- Hot start video:
      -- Riding video:
- OEM 04/05 Rear Brake Pedal - $10
   -- Great shape, just a little dirty
- OEM 04/05 Rear Brake Light - SOLD
   -- Great shape, works well, has silver spray paint over-spray on it
- OEM 04/05 Rear Bearing Carrier - $25
   -- Just bought this from skellington; but decided to go a different direction
- OEM 04/05 Parking/E-Brake Complete Setup w/ Cable - $10
   -- Great shape, little dirty, has silver spray paint over-spray on it
- OEM 04/05 Head Light - $75
   -- Comes with mounting brackets and bulbs - worked on high and low beam
- OEM 04/05 Red Front Plastics - $35
   -- Some scratching and slight fading, see pictures for condition
- OEM 04/05 Red Rear Plastics - $50
   -- Some scratching/fading; cut front-right piece; top screw mount ripped
- OEM 04/05 Front Shocks - SOLD
   -- Inner plastic shrouds have cracks; has silver spray paint over-spray on them
- OEM 04/05 Rear Shock - $25
   -- Inner plastic shroud is cracked; has silver spray paint over-spray on it
- OEM 04/05 Complete Rear End Setup - $95
   -- 04/05 Swing Arm w/ Hardware
   -- 04/05 Axle w/ lock-nut, brake caliper, stay, hubs, sprocket mount, carrier, and bearings
   -- Good shape and worked well; just dirty
- Wide Rear Grab Bar (w/ mounting hardware) - $25
   -- Might be very slightly bent upwards; also has scratches from normal use
- Bull Horn Front Bumper - $25
   -- No clue what brand this is; great for a woods racer/rider
   -- Has some bends, dents, and dings (see pics)
   -- Also has some sort of red paint on the back of it?
- Unknown Brand Skid Plate w/ Mounting Hardware - $15
   -- Extremely thick and strong
   -- Lots of dents and scratches; great for a woods racer though
- Alba Elite Nerf Bars (with mounting hardware - not all spacers tho) - $45
   -- Right side nerf nets are ripped in two places
   -- Left side nerf looks like it might have a slight bend in the front?
   -- Despite their issues - these are actually very nice nerf bars
- Chain and Sprocket Set (nice set) - $30
   -- 13T Front Sprocket
   -- 38T Rear Sprocket
   -- 94 Link RK EKW X-Ring Chain w/ Master Link
- Maxxis Razr MX 18x10-9 Rear Tires on OEM 9x8 Honda Wheels - $20
   -- Rough shape but still work pretty darn good for what they are
   -- Wheels are painted black and are pretty worn with lots of scratches and dents (don't think they are bent tho)
   -- Tires are worn; probably about 50% tread life left; one tire has a rip - no leaks or plugs tho
- Maxxis Razr MX 20x6-10 Front Tires on OEM 10x5.5 Honda Wheels - $30
   -- Wheels are painted black and are very worn with lots of scratches and bends
   -- Tires are worn; probably about 40%-50% tread life left; no leaks, plugs, or rips
- Ohtsu M/R 501 Rear Tires - 20x10-9 - $100
   -- Great shape; no plugs, rips, tears, or leaks
   -- Approximately 80-85% tread life left
   -- Great tires for trails, sand, drags, hill-climbs, etc.
- 04/05 Wicked Motors, MD Ported Cylinder Head - $400
   -- This is the head I used from 2008 - 2012; it's cut for 37/31 valves (+1mm in all 4)
   -- It has epoxy on the floor and roof of the intake port and in the exhaust port also (not posting pics, sorry)
   -- It made 56hp/36tq as a stock bore/stroke with a small DASA filter, 43.5mm FCR, HC Stage 3, full length DASA, and crappy Sunoco 110 fuel (see dyno sheet for proof)
   -- It received new KW +1 valves in 2012; which now have 1 season of racing on them (included, but not sure if they are still in spec?)
   -- Head is decked .060", received a Serdi valve job in 2012, and I THINK it has bronze guides and copper berrylium seats (can't remember for sure tho)
   -- Perfect head for use in conjunction with a DASA Loretta Lynn's piston
- CP M2035 94mm 12:1 Piston (used for maybe 4-5 hours total) - $95
   -- With Wrist Pin, Original Box, etc.
   -- No clue if this is still in spec - but it definitely should be
- Wiseco 13.1:1 94mm Piston - $35
   -- Used for maybe 20-25 hours; still has the coating on the skirts
   -- No clue if this is still in spec?
- Rage CP 13:1 Race 94mm Piston for Decked Heads - $45
   -- Nicely designed piston for plenty of clearance with .060" off a head (makes for 15:1+ comp)
   -- No clue if this is still in spec or not
- ESR Intake w/ Filter (epoxy mod'd w/ boot) - $40
- Complete 04/05 TRX450R Fuel Customs Intake Setup (brand new, never used) - SOLD
   -- Comes with filter, outerwears, boot, and all mounting hardware for w/ or w/o the airbox
- 48mm Packard Enterprises Lectron Carb (boot not included) - $395
   -- Packard Billet Bowl
   -- PE-4 Needle (perfect for gas or oxy fuel)
   -- Single Powerjet
   -- Perfect shape and works great
- DASA Quiet Core and Spark Arrestor Combo Deal - SOLD
- FMF Factory 4 Slip-on Silencer w/ Rear Mount - $25
   -- Rougher shape with scratches and a small dent - still sounded pretty good tho
By far the best for-sale add I've seen.
BUMP for a guy that knows how to properly list parts. Good luck with your sale
Thanks brotha, appreciate the kind words.
May need a few things. Let me check the wife's wallet
LMK mang!  Check her wallet twice ;)
Stator is sold also.
Sorry man, after pricing the shipping on the complete rear-end...I don't think I'm going to ship it.  I will, more than likely, be breaking it down next weekend and selling pieces from it individually.  A lot of these parts have sold and I can't edit the original post...so I'll be making a new thread with the leftover parts + some others soon.
  • 1 year later...
