tdod101 Posted July 23, 2014 Report Share Posted July 23, 2014 So I've found some time to work on my motor now. Got my full clip in around the crank but what's with these little tabs ? Anything specific with them ? Location ? Hot rods 4 mil long rod Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted July 23, 2014 Report Share Posted July 23, 2014 Those are pins. There is a small recess in the case for them to rotate into and sit to keep them from spinning in the cases Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted July 23, 2014 Report Share Posted July 23, 2014 Crank seal is in wrong. Quote Link to comment Share on other sites More sharing options...
tdod101 Posted July 23, 2014 Author Report Share Posted July 23, 2014 Not sure I understand, so into the top case half or just point against that little flat spot on the bottom case. It's your crank skeet Quote Link to comment Share on other sites More sharing options...
tdod101 Posted July 23, 2014 Author Report Share Posted July 23, 2014 Crank seal is in wrong. Oops thank you. So like this than ? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted July 23, 2014 Report Share Posted July 23, 2014 Yep. And sprink is correct about seal. It will work either direction though. But the correct way is opposite of your pic Quote Link to comment Share on other sites More sharing options...
tdod101 Posted July 23, 2014 Author Report Share Posted July 23, 2014 Thanks guys, so the dowels are in correct position and seal is turned around. Time to put the top half on, here goes nothing Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted July 23, 2014 Report Share Posted July 23, 2014 You forgot to get better bearings. Some max loads would of been good assurance. Quote Link to comment Share on other sites More sharing options...
