I have a set of gray stock a-arms in good condition. None of the boots are ripped, everything was tight when I took them off, I just upgraded.. The a-arms have some paint worn off as seen in the photos, and the bottom right a-arm has a ding in the back side. I believe all the hardware is there with the exception of one dust cap that is probably on the floor in my garage (if I can find it, it will be included, but assume it's not). The only other problem is that one of the long bolts for the top a-arms had some corrosion on it and was difficult to get out. It will need to have that wire wheeled off before reassembly unless you already have the bolt.
A-arms $75 shipped
Tie rods $15. Shipped
Spindles with brake rotors $40 Shipped
stock shocks $65 shipped
  • 4 weeks later...
