EaCastillo00 Posted June 11, 2016 Report Share Posted June 11, 2016 ok, so my banshee has mikuni stock carbs, K&N pro flow kit, Toomey T5 pipes, 0.50 overbore engine, just changed jets 280 main, 27.5 pilots, the question is: which needle clip position would be best? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted June 12, 2016 Report Share Posted June 12, 2016 I'm at 1400 ft, stock needle, middle position... and the exact same set-up. Quote Link to comment Share on other sites More sharing options...
EaCastillo00 Posted June 12, 2016 Author Report Share Posted June 12, 2016 I'm at 1400 ft, stock needle, middle position... and the exact same set-up. im at 380 ft Quote Link to comment Share on other sites More sharing options...
EaCastillo00 Posted June 12, 2016 Author Report Share Posted June 12, 2016 im at 380 ft i investigated, im about the same height as you, but my citys altitude is very variable, so im about the same height as you Quote Link to comment Share on other sites More sharing options...
