First plug chop with PWK
Craig B
I just installed a new set of 35mm Pwk's the other day. I did a shakedown pass with it today 48 degrees out. The jetting is 160 mains 48 pilot , cel w/clip in the middle. Seems to run strong , but showing PIG fat for sure. Fuel is VP C-12 w/ 927 @ 32 to 1. How much would you drop down on the main? Motor was hot and I installed a fresh plug and did a 500 to 600 ft 6 speed blast shutting it down. Then installing the old plug back in it. Thanks foFirst%20Plug%20Chop%20PWK%201-3-16_zpsebr any help.
how do you like the pipes? Notice a big difference with the bigger carbs in performance?
Hard to tell at the moment until I get this dialed in with the jetting so rich. I may try to dyno this in the next week or so. Then maybe have some better feedback for you.
  • Like 1
