Syncing carbs with tool
Can you sync carbs with tool while choke is on. I ask this because I just got done with full rebuild and it won't idle with choke off. So I haven't even been able to do proper break in. I wanted to sync carbs first then do break in but right side carb is at 1.5 and left is at 6, is that because I'm trying to sync with choke on.
sync them by eye first, so the slides open and close at the exact same time, watch when they just barely go past the top of the carb opening on WOT (bike off of course), so they are somewhat close, then clean or rejet or find air leak etc then use the tool when its running good.  You can get it running good without the tool.
lol, they are pretty crappy, but its should be the same as looking at the bottom of the slides compared to the top of the bores looking down the carbs, shouldn't it?  Thats easier anyways cause i can see them both while moving the throttle.  After using the vac sync tool though the left side is maybe 1mm lower than the right when Wide open to get even vac on the tool mid throttle.
