dome numbers
mx1986
CC , angle, and "step" or lip at the outer edge of the squishband in thousandths. They may have damaged a dome at one time and used another good dome in a pinch. 2 thousandths isnt a huge deal really if squish isnt on the tight side. Check squish for sure and you may find that the squish is off by 2 thous or they may be the same. I have seen numerous sets of brand new domes out of the box that the step was 1 or 2 thousandths different.
Yeah. 4 different My bad. Probably had an alky set with tighter squish and a gas set with looser squish and mixed and matched a spare after messin one up. I run the same compression but tighter squish and a bit different dome on alky.
