oldskool Posted July 9, 2015 Report Share Posted July 9, 2015 I have a stock frame, stock a-arms, +10 swingarm banshee that I only play with on a hard pack drag strip. With this set-up it does great with studded tires, but not on rubber. I've tried 501 ohtsu, 4snow and cut ambush. I had a +6 swinger and it did fair on rubber, but a handful with studs sometimes. My question is, if I went back to a +6 and +3 forward a-arms, would that be a better set-up to run rubber tires and still run studs sometimes. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 9, 2015 Report Share Posted July 9, 2015 The more weight you get over the tires the better. You should get better power transfer with the +6 rear and +3 front than the stock front and +10 swingarm. What do you have for rear suspension? Quote Link to comment Share on other sites More sharing options...
oldskool Posted July 9, 2015 Author Report Share Posted July 9, 2015 coil over shaw Quote Link to comment Share on other sites More sharing options...
