4 mil build
bansman76
hey guys. need a ballpark idear to start jetting on:
hot rod 4 mil crank
.40 over cylinders-play/dune port for 4 mil by f.a.s.t
pro circuit pipes
stock airbox no lid with pro flow adapter and k&n filter
+4 timing.
pro design head with 23cc pump gas domes
140lbs of compression each side
1200 ft above sea level
   thanks for the advice
Emailed f.a.s.t Jeff said 27.5 pilot. An start with 340 main. I currently have it running on 27.5 middle clip. And 340 main. Starts easy and runs good but when I check the plugs on the pilot jet check it looks lean to me( going by the jetting info in the tech section ). Haven't done the mains plug chop yet but that will be done this wknd. Thanks for any and all advice guys. I am no jetting guru lol
i rode it for a few this evening in the yard lol.  had just a slight stumble going from idle to 1/2 throttle.   i played with the air screws a little and got the stumble gone i believe and the idle sounds better.  i have the airscrews at 1 turn out from lightly seated.  should i still go ahead and put the 30 pilots in or should i wait and do the mains first ?   thanks guys
If you're 1 turn out, yes, go to a 30 pilot.
With idle screws installed and TORS eliminated I set my idle to 1500rpms with a digital tach from ebay.
http://www.ebay.com/itm/LCD-Digital-Engine-Tach-Hour-Meter-Gauge-for-Racing-Motorcycle-Black-US-STOCK-/291261653224
I also sync my carbs with a FAST Carb Sync Tool http://www.farmandsandtoys.com/partdetail.asp?partid=59 at idle and ~5500rpms.
How to sync, in case you do not know.
Part 1 https://youtu.be/8FDcsojwVxc
Part 2 https://youtu.be/IZEBfFZUygM
Dialing in the airscrews should be done after the above tuning is complete.
You can feel and hear the throttle crack open sharply with no stumble off idle when your airscrews are dialed.
Thanks for the advice guys. I actually have a sync tool but forgot all about doing that part. I did remember to eyeball the carbs. I'll be taking the air box back off to do that either tonight or tomo. I might say hell with airbox and put my 2into1 filter back on it for ease of jetting. Lol.
  • 2 weeks later...
Thanks for all the advice fellers. Removed airbox put toomey 2-1 air filter on for now (til I get pods). Installed 30 pilots for when I get V4's. 4th clip on needle. 350 main jet. Synced carbs and adjusted air screws. Done another plug chop today and sent pics to Jeff. He says I could safely drop to a 330-340 main and be fine. No stumbles , no flat spots. Shee runs great and very powerful. Big thanks to all
