jetting help
oberlez
Just wanting some ideas on what you guys think I should start out with for jetting. I race in Kansas and at the desert in OK. I have a 421 on alcohol with a k&t drag port, vf3's, 39 pwk with 10 inch filters, shear oof's. Any help would be appreciated. Again just wanting a starting point and so I can buy some extra jets that are in the right neighborhood.
You can't buy jets for alky someone has to set carbs up , do you have a power jet installed already ? Similar set up by me is .1225 dump/ main, 55 pilot and egn needle 2 clip , big bowls one float cut off and some little circuits drilled a lil bigger start pj 6 turns out and go from there and squeeze it down
