Shearer 2 into 1 Dune Pipe
  • 6 months later...
the 2-1 dynoport from back in the days barely made more power than the oem stock pipes...
if you want off idle to 4000 rpm power thats asking a lot from a motor designed to make power in the 7500 and up range..   it can be done but i feel would take a custom pipe made for that power range.  and proper porting to support it..    if you want low end tq and top end power its going to take a pv setup with a lot of compression.  should rev to 9500 and make good power if built right..
WOW  2010 on this one!!!!!
  • 4 months later...
